I am using WP7702 with a mangoh yellow to run some tests and in specific want to check connection and transmission from the device.
I am using AT commands (Above the COM port over the USB connected to my PC) and want to trigger a UMTS transmission. First, I enter debug mode and configure the band, channel, power etc… for the transmission and start transmission with TXON command. I can see the device transmitting using a spectrum analyzer in the frequency I configured.
It is important to note that in this mode the device has no sim card and hence is not connected to a network.
From what I managed to understand from the documentation, the UL scrambling code in the transmission is not configurable.
Can you tell me what is the scrambling code or how can I find it?
Thank you in advance,
Adam
