[WP7504] Can't Reset User Parition via swiflash
Hi everyone,
I’m having an issue resetting the user partition on my WP7504 module. I’m using the command:
swiflash -m "wp750x" -r
It outputs the following:
Detecting USB of the target
DONE
Communicating with the Target
DONE
Switching to firmware download mode
…and it just keeps outputting periods / dots forever. This is particularly strange, as I reset the user partition just last week without issue. However, I did attempt a new Legato platform installation on this device, so I’m wondering if there’s some factor there.
I’m using a dedicated Debian Linux install, so it’s not in a VM.
Thank you very much in advance for any possible advice/insight!
Hey CoffeeMan64,
I am having the same problem. I’m sure you’ve gotten past this by now, but I got around it by pulling the TP1 pin low before powering on the device. After about 2-3 minutes, I power cycle the device and let TP1 float again, which seems to work, but it’s really annoying. Did you ever resolve this?
Hi @CoffeeMan64,
If you face this issue, forcing module to bootloader mode may be the best practice. Please try the part “Troubleshooting” at link below:
https://source.sierrawireless.com/resources/airprime/software/swiflash/#sthash.28kkbZ2p.dpbs
