+WIPDATA indication issue
Dear all,
I’m using Wismo228 module to implement GPRS feature. I have to use both online data mode and at mode ( for receiving SMS ). Then I swap between these modes. The problem that I meet is: There is only one time I can receive TCP package +WIPDATA indication when unit is in AT mode. I switch to online data mode, read the data and go back to AT mode. After that I don’t receive any +WIPDATA indication. Even there is coming data from the server. I test many time and all are same situation. Can anyone help me please ?
I send the log below:
AT+WIPCFG=1
AT+WIPBR=1,6
AT+WIPBR=4,6,0
AT+WIPCREATE=2,5,“www.teamtekbox.com”,30175
+WIPREADY: 2,5
AT+WIPDATA=2,5,2
CONNECT
$FRLIN,anh,SMZ50 <-- login to server
$FRSES,804
41
< transfer data to server >
+++ <— switch to AT mode
<from the server I send “hello” >
+WIPDATA: 2,5,5 <-- there is TCP package indication
AT+WIPDATA=2,5,2
CONNECT
hello
+++ <— switch to AT mode again
< from the server I send “hello” >
AT+WIPDATA=2,5,2
CONNECT
+WIPPEERCLOSE: 2,5
Best Regards,
Nguyen Hoang Anh
Are you using outdated FW?
Otherwise try the latest FW and check if it solves the problem.
Thx.
L
Dear lotam,
Thanks in advance. I have got the new firmware and try to upgrade it now.
Will let you know the result.
Regards,
Anh
Hi Anh,
You are welcome. Good luck and come back with a good news.
:slight_smile:
L
Dear,
I upgraded firmware L22_00gg.WISMO218 281210 and the module worked as my expectation.
Again thanks lotam too much : ).
Regards,
Anh
