I need to send data to web server using HTTP Post method. I tried the code given in these forums. I was able to send data through HTTP post method only once. For second time I am getting HTTP 400 Error Response. I have to restart my Wavecom Modem in-order to send data again. Please suggest me any solution regarding this issue. In this post its said to close channels manully, but while doing so it says I am trying to close channel which is null. My code is as follows:
#include "wip.h"
#define RECBUFF 400
/////////External Function Declarations
extern void InboundData(char *Data);
/////////Local Function Declarations
s32 http_Client(void);
void KillHTTP(void);
////////External Variable Declarations
extern char *Data_PCKT;
////////Local Variable Declarations
static u8 rcv_buffer [RECBUFF];
const ascii * HTTP_STR_URL = "http://lightmatrix.net/TEST/DEFAULT.ASPX";
int BytesWritten, code;
s32 status;
ascii info[50];
ascii *tmpbuf;
static int offset = 0;
typedef struct
wip_channel_t CnxChannel; // session channel
wip_channel_t DataChannel; // data channel
u32 dataLength; // response data length
}http_ClientTestCtx_t;
http_ClientTestCtx_t http_ClientTestCtx;
void KillHTTP(void)
int i = 0;
wip_debug("\r\nKilling HTTP Handler...\r\n");
if (http_ClientTestCtx.CnxChannel != NULL)
http_ClientTestCtx.CnxChannel = NULL;
if (http_ClientTestCtx.DataChannel != NULL)
http_ClientTestCtx.DataChannel = NULL;
for(i=0;i<RECBUFF;i++)
rcv_buffer[i] = 0;
for(i=0;i<50;i++)
info[i] = 0;
wip_debug("\r\nHTTP Handler killed...\r\n");
static void http_ClientTestDataHandler( wip_event_t *ev, void *ctx)
//s16 m,n,p,w;
int tmp = 0;
http_ClientTestCtx_t *pHttpClientCtx = (http_ClientTestCtx_t *) &http_ClientTestCtx;
switch(ev->kind)
case WIP_CEV_OPEN: wip_debug("\r\nhttp_ClientTestDataHandler: Start\r\n");
break;
case WIP_CEV_READ: wip_debug("\r\nhttp_ClientTestDataHandler: WIP_CEV_READ\r\n");
wip_getOpts(http_ClientTestCtx.DataChannel, WIP_COPT_HTTP_STATUS_CODE, &code, WIP_COPT_END);
wm_sprintf( info, "\r\nHTTP Status code: %d\r\n", code);
wip_debug(info);
if (code == 200)
int nread,i;
nread = wip_read( ev->channel, rcv_buffer,RECBUFF);
if( nread < 0)
wip_debug( "\n[client]Unable to read. Error %i\n", nread);
return;
// wip_debug( "\n[client]Data received is %s\n", rcv_buffer);
nread = -1;
tmp = 0;
if(rcv_buffer[i] == '~')
tmp = 1;
if(tmp==1)
rcv_buffer[i] = '\0';
InboundData(rcv_buffer);
do
wip_debug( "\n[client]Trying to close Data Channel.\n");
wip_close( http_ClientTestCtx.DataChannel);
adl_ctxSleep(100);
}while(wip_getState(http_ClientTestCtx.DataChannel) == WIP_CSTATE_READY);
do
wip_debug( "\n[client]Trying to close CX Channel.\n");
wip_close( http_ClientTestCtx.CnxChannel);
adl_ctxSleep(100);
}while(wip_getState(http_ClientTestCtx.CnxChannel) == WIP_CSTATE_READY);
adl_ctxSleep(2000);
Business_Logic();
if (code == 400)
wip_debug( "\nChannel Unstable...\n");
if(wip_getState(http_ClientTestCtx.CnxChannel) == WIP_CSTATE_READY)
wip_debug( "\n[client]Successfully to close CX Channel.\n");
else
wip_debug( "\n[client]Failed to close CX Channel.\n");
code = 0;
// wip_close( http_ClientTestCtx.DataChannel);
// wip_close( http_ClientTestCtx.CnxChannel);
break;
case WIP_CEV_WRITE:
tmpbuf = 0;
tmpbuf = adl_memGet(strlen(Data_PCKT)+3);
wm_sprintf(tmpbuf,"Q=%s",Data_PCKT);
wip_debug("\nSize of TMPBUF is %d. TMPBUF has : %s\n",strlen(tmpbuf),tmpbuf);
wip_debug("\r\nhttp_ClientTestDataHandler: WIP_CEV_WRITE\r\n");
BytesWritten = wip_write( http_ClientTestCtx.DataChannel, tmpbuf, (strlen(tmpbuf)+1)-offset);
if(BytesWritten < 0)
{/* error */
wip_debug( "HTTP write error %i\n", BytesWritten);
wip_debug( "\r\nwip_write error\r\n" );
return;
offset += BytesWritten; /* Update the number of bytes sent. */
if( offset == strlen(tmpbuf)+1)
{ /* All of [buffer] has been sent */
wm_sprintf( info, "\r\nhttp_ClientTestDataHandler: %d bytes written\r\n", offset);
wip_debug(info);
// wip_shutdown( http_ClientTestCtx.DataChannel,FALSE,TRUE);
adl_memRelease (tmpbuf);
tmpbuf = NULL;
wip_debug( "\r\nTMPBUFF is freed\r\n" );
break;
case WIP_CEV_PEER_CLOSE: wip_debug("\r\nhttp_ClientTestDataHandler: Done\r\n" );
// end of data
// show response information
if( wip_getOpts( ev->channel,WIP_COPT_HTTP_STATUS_CODE, &status,WIP_COPT_HTTP_STATUS_REASON, tmpbuf, strlen(tmpbuf),WIP_COPT_END) == OK)
ascii sbuf[16];
wip_debug("http_ClientTestDataHandler: Status=" );
wm_sprintf( sbuf, "%d", status);
wip_debug(sbuf);
wip_debug( "\r\nhttp_ClientTestDataHandler: Reason=\"" );
wip_debug(tmpbuf);
wip_debug( "\"\r\n" );
if( wip_getOpts( ev->channel,WIP_COPT_HTTP_HEADER, "content-type", tmpbuf, strlen(tmpbuf),WIP_COPT_END) == OK)
wip_debug("http_ClientTestDataHandler: Content Type=\"%s\"\n", tmpbuf);
wip_debug("http_ClientTestDataHandler: Response Length=%d bytes\n",pHttpClientCtx->dataLength );
// data channel must be closed
wip_close( ev->channel);
break;
case WIP_CEV_ERROR: wip_debug("http_ClientTestDataHandler: WIP_CEV_ERROR %d\n",ev->content.error.errnum);
//adl_atSendResponse ( ADL_AT_UNS, "http_ClientTestDataHandler: ERROR\r\n" );
wip_debug( "\r\nhttp_ClientTestDataHandler: ERROR\r\n");
// connection to server broken
break;
default: wip_debug("http_ClientTestDataHandler: unexpected event: %d\n",ev->kind);
wip_debug("\r\nunexpected event\r\n");
break;
s32 ret = 0;
char conlen[3];
// HTTP Session creation
wm_sprintf(conlen,"%03d",strlen(Data_PCKT)+3);
wip_debug("\nCONLEN = %s\n",conlen);
wip_debug( "\nCX Channel State before Initialisation....\n" );
switch(wip_getState(http_ClientTestCtx.CnxChannel))
case WIP_CSTATE_BUSY: wip_debug( "\nCX Channel Busy....\n" );
break;
case WIP_CSTATE_READY: wip_debug( "\nCX Channel Open and Ready...\n" );
wip_close(http_ClientTestCtx.CnxChannel);
http_Client();
return 0;
case WIP_CSTATE_TO_CLOSE: wip_debug( "\nCX Channel Ready to close....\n" );
break;
// http_ClientTestCtx.CnxChannel = NULL;
http_ClientTestCtx.CnxChannel = wip_HTTPClientCreateOpts( NULL, // no handler
NULL, // no context
// default headers
WIP_COPT_HTTP_HEADER, "User-Agent", "HTTP/1.1",
WIP_COPT_END);
if (http_ClientTestCtx.CnxChannel == NULL)
wip_debug( "\ncannot create http session channel\n" );
//adl_atSendResponse ( ADL_AT_UNS, "cannot create http session channel\r\n" );
wip_debug("\r\ncannot create http session channel\r\n");
ret = -1;
else
wip_debug( "\r\nhttp session channel created\r\n");
// HTTP POST command
// http_ClientTestCtx.DataChannel = NULL;
http_ClientTestCtx.DataChannel = wip_getFileOpts(
http_ClientTestCtx.CnxChannel, // session channel
HTTP_STR_URL, // URL to receive the data
http_ClientTestDataHandler, // data handler
&http_ClientTestCtx, // context
WIP_COPT_HTTP_METHOD, WIP_HTTP_METHOD_POST,
// request headers
WIP_COPT_HTTP_HEADER, "Content-Type", "application/x-www-form-urlencoded",
WIP_COPT_HTTP_HEADER, "Content-Length", conlen,
WIP_COPT_HTTP_HEADER, "Accept", "text/html", WIP_COPT_END);
if (http_ClientTestCtx.DataChannel == NULL)
wip_debug( "cannot create http data channel\n" );
wip_debug( "\r\ncannot create http data channel\r\n");
// ret =-1;
else
wip_debug( "\r\nHTTP data channel created\r\n");
return(ret);
