Hi all,
I have tried to use HTTP post to call the web service that is created by ASP.NET and running in IIS 5.1, Through the tcp protocol analysis tool of Wireshark, it can be found that the web service can receive the request of the http post, and sent the right result to the modem (Fastrace Supreme 10), However in modem side, the req_event of WIP_CEV_READ also can be triggered, but there is not any data that can be read by wip_read(), see the code as below, and the code is based on the example code of HTTP GET, the WIP library version is 5.00.2050,
* File : entry_point.c
* HTTP application:
* - Configure url [HTTP_STR_URL]
$LogWavecom$
* Date | Author | Revision | Description
* 25.01.07 | RFN | 1.0 | Initial revision
* 12.03.08 | MBU | X.X | Correction of tracker ANO46671
#include "adl_global.h" // Global includes
#include "wip_http.h" // WIP http services
/* Local variables */
// HTTP defined strings set
const ascii * HTTP_STR_URL = "http://server_xxx/webservice/Service1.asmx/MyAdd";
const ascii * HTTP_POST_CONTENT = "i=1&j=7";
typedef struct
wip_channel_t CnxChannel; // session channel
wip_channel_t DataChannel; // data channel
u32 dataLength; // response data length
} http_ClientTestCtx_t;
http_ClientTestCtx_t http_ClientTestCtx;
/* Constants */
/* Local functions */
/* Function : http_ClientTestDataHandler */
/* Object : Handler for the HTTP data channel */
/* Returned : none */
/* Variable Name |IN |OUT|GLB| Use */
static void http_ClientTestDataHandler( wip_event_t *ev, void *ctx)
ascii tmpbuf[512];
ascii Ptr_OnTrace[512];
int len, tmplen;
s32 status;
http_ClientTestCtx_t *pHttpClientCtx =
(http_ClientTestCtx_t *) &http_ClientTestCtx;
s16 retWrite = 0;
ascii msgbuf[50] = "i=1&j=7";
switch(ev->kind)
case WIP_CEV_OPEN:
TRACE(( 4, "http_ClientTestDataHandler: WIP_CEV_OPEN\n" ));
adl_atSendResponse ( ADL_AT_UNS, "http_ClientTestDataHandler: Start\r\n" );
// ready for getting response data
pHttpClientCtx->dataLength = 0;
break;
case WIP_CEV_READ:
TRACE(( 4, "http_ClientTestDataHandler: WIP_CEV_READ\n" ));
adl_atSendResponse ( ADL_AT_UNS, "\r\nhttp_ClientTestDataHandler: WIP_CEV_READ\r\n" );
// we must read all available data to trigger WIP_CEV_READ again
tmplen = 0;
while ( (len = wip_read( http_ClientTestCtx.DataChannel/*ev->channel*/, tmpbuf, sizeof(tmpbuf)-1)) > 0 )
tmpbuf[len] = 0;
adl_atSendResponse ( ADL_AT_UNS, tmpbuf );
tmplen += len;
adl_atSendResponse ( ADL_AT_UNS, "\r\nhttp_ClientTestDataHandler: wip_read: 1\r\n" );
TRACE(( 4, "http_ClientTestDataHandler: read %d bytes\n", tmplen ));
wm_sprintf(Ptr_OnTrace, "\r\n http_ClientTestDataHandler: read totally %d bytes\n", tmplen);
adl_atSendResponse ( ADL_AT_UNS, Ptr_OnTrace );
// compute total length of response
pHttpClientCtx->dataLength += tmplen;
break;
case WIP_CEV_WRITE:
TRACE(( 4, "http_ClientTestDataHandler: WIP_CEV_WRITE\n" ));
adl_atSendResponse ( ADL_AT_UNS, "\r\nhttp_ClientTestDataHandler: WIP_CEV_WRITE\r\n" );
retWrite = wip_write(http_ClientTestCtx.DataChannel/*ev->channel*/, msgbuf, wm_strlen(msgbuf));
// Need to signal the end of the message body
wip_shutdown(http_ClientTestCtx.DataChannel/*ev->channel*/, FALSE, TRUE);
break;
case WIP_CEV_PEER_CLOSE:
TRACE(( 4, "http_ClientTestDataHandler: WIP_CEV_PEER_CLOSE\n" ));
// end of data
// show response information
if( wip_getOpts( http_ClientTestCtx.DataChannel/*ev->channel*/,
WIP_COPT_HTTP_STATUS_CODE, &status,
WIP_COPT_HTTP_STATUS_REASON, tmpbuf, sizeof(tmpbuf),
WIP_COPT_END) == OK)
ascii sbuf[16];
adl_atSendResponse ( ADL_AT_UNS, "http_ClientTestDataHandler: Status=" );
wm_sprintf( sbuf, "%d", status);
adl_atSendResponse ( ADL_AT_UNS, sbuf);
adl_atSendResponse ( ADL_AT_UNS, "\r\nhttp_ClientTestDataHandler: Reason=\"" );
adl_atSendResponse ( ADL_AT_UNS, tmpbuf);
adl_atSendResponse ( ADL_AT_UNS, "\"\r\n" );
TRACE(( 4, "http_ClientTestDataHandler: Status=%d\n", status));
wm_sprintf(Ptr_OnTrace, "http_ClientTestDataHandler: Reason=\"%s\"\n", tmpbuf);
TRACE((4,Ptr_OnTrace));
WIP_COPT_HTTP_HEADER, "content-type", tmpbuf, sizeof(tmpbuf),
wm_sprintf(Ptr_OnTrace, "http_ClientTestDataHandler: Content Type=\"%s\"\n", tmpbuf);
TRACE(( 4, "http_ClientTestDataHandler: Response Length=%d bytes\n",
pHttpClientCtx->dataLength ));
// if OK, and finished
if (status == 200)
// data channel must be closed
wip_close( http_ClientTestCtx.DataChannel/*ev->channel*/);
break;
case WIP_CEV_ERROR:
TRACE(( 4, "http_ClientTestDataHandler: WIP_CEV_ERROR %d\n",
ev->content.error.errnum));
adl_atSendResponse ( ADL_AT_UNS, "http_ClientTestDataHandler: ERROR\r\n" );
// connection to server broken
break;
default:
TRACE(( 4, "http_ClientTestDataHandler: unexpected event: %d\n",
ev->kind));
break;
/* Function : http_ClientTestCreate */
/* Object : HTTP get example */
static s32 http_ClientTestCreate(void)
s32 ret = 0;
// HTTP Session creation
http_ClientTestCtx.CnxChannel = wip_HTTPClientCreateOpts(
NULL, // no handler
NULL, // no context
// default headers
WIP_COPT_HTTP_HEADER, "User-Agent", "WIPHTTP/1.0",
WIP_COPT_END);
if (http_ClientTestCtx.CnxChannel == NULL)
TRACE(( 1, "cannot create http session channel\n" ));
adl_atSendResponse ( ADL_AT_UNS, "cannot create http session channel\r\n" );
ret = -1;
else
// HTTP GET command
http_ClientTestCtx.DataChannel = wip_getFileOpts(
http_ClientTestCtx.CnxChannel, // session channel
HTTP_STR_URL, // requested URL
http_ClientTestDataHandler, // data handler
//&http_ClientTestCtx, // context
NULL,
WIP_COPT_HTTP_METHOD, WIP_HTTP_METHOD_POST,
WIP_COPT_HTTP_HEADER, "Content-Type", "application/x-www-form-urlencoded",
// request headers
WIP_COPT_HTTP_HEADER, "Accept", "text/xml",
WIP_COPT_END);
if (http_ClientTestCtx.DataChannel == NULL)
TRACE(( 1, "cannot create http data channel\n" ));
adl_atSendResponse ( ADL_AT_UNS, "cannot create http data channel\r\n" );
wip_close( http_ClientTestCtx.CnxChannel);
ret =-1;
return(ret);
/* Function : appli_entry_point */
/* Object : Called once the WIP IP stack is fully initialized. */
/* This is the starting point of user applications. */
/* Variable Name |IN |OUT|GLB| Utilisation */
void appli_entry_point(void)
TRACE (( 1, "HTTP Client Service test application : Init" ));
adl_atSendResponse ( ADL_AT_UNS, "\r\nHTTP Client Service test application : Init\r\n" );
http_ClientTestCreate();
So why the wip_read() can not read any data after the web service has been sent the right result to modem?
Is there anyone can help me? thank you very much.
