WIP_BOPT_ERROR 220 Undocumented?
I’m doing GPRS session with FXT001 acting as client connecting to a pc server-side.
In “GprsBearer_EventHandler(wip_bearer_t bearer, s8 event, void * context)” i receive WIP_BEV_CONN_FAILED, so i call wip_bearerGetOpts() as following code:
if (wip_bearerGetOpts(gprs_Bearer, WIP_BOPT_ERROR, &error, WIP_BOPT_END) == 0)
  TraceGprsError(error);
In function TraceGprsError() i evaluate all possible case of errors:
void TraceGprsError(int error)
	switch(error)
		case WIP_BERR_NO_DEV: TRACE((TDL_GPRS, "WIP_BERR_NO_DEV")); break;
		case WIP_BERR_ALREADY: TRACE((TDL_GPRS, "WIP_BERR_ALREADY")); break;
		case WIP_BERR_NO_IF: TRACE((TDL_GPRS, "WIP_BERR_NO_IF")); break;
		case WIP_BERR_NO_HDL: TRACE((TDL_GPRS, "WIP_BERR_NO_HDL")); break;
		case WIP_BERR_BAD_HDL: TRACE((TDL_GPRS, "WIP_BERR_BAD_HDL")); break;
		case WIP_BERR_OPTION: TRACE((TDL_GPRS, "WIP_BERR_OPTION")); break;
		case WIP_BERR_PARAM: TRACE((TDL_GPRS, "WIP_BERR_PARAM")); break;
		case WIP_BERR_OK_INPROGRESS: TRACE((TDL_GPRS, "WIP_BERR_OK_INPROGRESS")); break;
		case WIP_BERR_BAD_STATE: TRACE((TDL_GPRS, "WIP_BERR_BAD_STATE")); break;
		case WIP_BERR_DEV: TRACE((TDL_GPRS, "WIP_BERR_DEV")); break;
		case WIP_BERR_NOT_SUPPORTED: TRACE((TDL_GPRS, "WIP_BERR_NOT_SUPPORTED")); break;
		case WIP_BERR_LINE_BUSY: TRACE((TDL_GPRS, "WIP_BERR_LINE_BUSY")); break;
		case WIP_BERR_NO_ANSWER: TRACE((TDL_GPRS, "WIP_BERR_NO_ANSWER")); break;
		case WIP_BERR_NO_CARRIER: TRACE((TDL_GPRS, "WIP_BERR_NO_CARRIER")); break;
		case WIP_BERR_NO_SIM: TRACE((TDL_GPRS, "WIP_BERR_NO_SIM")); break;
		case WIP_BERR_PIN_NOT_READY: TRACE((TDL_GPRS, "WIP_BERR_PIN_NOT_READY")); break;
		case WIP_BERR_GPRS_FAILED: TRACE((TDL_GPRS, "WIP_BERR_GPRS_FAILED")); break;
		case WIP_BERR_PPP_LCP_FAILED: TRACE((TDL_GPRS, "WIP_BERR_PPP_LCP_FAILED")); break;
		case WIP_BERR_PPP_AUTH_FAILED: TRACE((TDL_GPRS, "WIP_BERR_PPP_AUTH_FAILED")); break;
		case WIP_BERR_PPP_IPCP_FAILED: TRACE((TDL_GPRS, "WIP_BERR_PPP_IPCP_FAILED")); break;
		case WIP_BERR_PPP_LINK_FAILED: TRACE((TDL_GPRS, "WIP_BERR_PPP_LINK_FAILED")); break;
		case WIP_BERR_PPP_TERM_REQ: TRACE((TDL_GPRS, "WIP_BERR_PPP_TERM_REQ")); break;
		case WIP_BERR_CALL_REFUSED: TRACE((TDL_GPRS, "WIP_BERR_CALL_REFUSED")); break;
		case WIP_BERR_NO_MEM: TRACE((TDL_GPRS, "WIP_BERR_NO_MEM")); break;
		default:
			TRACE((TDL_GPRS, "NO ERROR CODE FOUND."));
		break;
But i get 220 as error code returned by wip_bearerGetOpts() which is not covered in “wip_bearer.h”.
What does it means this error code ?
I haven’t ever encountered this problem. Looking through your code I noticed that your function TraceGprsError(int error) takes an INT as an input.
What I would try is making your variables all s8, as the documentation suggests.
eg.
s8 error;
void TraceGprsError(s8 error)
   switch(error)
      default:
      break;
Tyrone
Thanks.
