Sorry for misunderstand.
I said Ubuntu has no problem means there is no error out when I execute these commands. My test platform is Ubuntu. So I need your test result to see if any step or other environment issue in my side.
- change “int iIPAlias=0;” in GobiUSBNet.c .
- recompile and install your GobiNet driver.
- “sudo rmmod GobiNet” to remove current loaded GobiNet which is the old one.
- when module (with AT!NETNUM set to 2) plugged in, new GobiNet driver will be loaded.
- you can check “cat /sys/module/GobiNet/parameters/iIPAlias” which should be zero
- “gobi-0-0” is seen in ifconfig
I tried above on SierraLinuxQMIdriversS2.38N2.59 with Ubuntu18.04.
It works!!
Thank you !!
