whether the replacement Q24PL003 module? THANKS
Hi
What you have asked is not very clear.Can you please reframe your question??
Hi paruthiv,
I want sending data between microcontrollers over GPRS and used TCP/IP via AT Command. Problems, Q24PL003 now is not available in the market, I want to replace the wireless cpu with the same specification, support RS232, full TCP/IP Stack over AT Command. Can you advise me, what is the appropriate wireless cpu? Thank You.
Q24 Plus module is discontinue, I prefer you use Fastrack Extend - FXT009 module as replacement.
If you want to replace only the wireless CPU, Q26 series is good choice.
