I am using the EM7455 but I sometimes have a weak signal. I am using Debian Linux and my code depends on reading the output of ‘ifconfig’ to make sure the EM7455 has an established connection. Many times throughout the day the virtual eth1 loses the virtual IP address established from the EM7455. I also monitor the connection using the SCACT=? AT command and it will return SCACT=1,0 which means I lost connection. What should my code do if I see SCACT=1,0. Do I reset the EM7455 and perform SCACT=1,1 or do I set a timeout period and hope it returns soon?
my ifconfig output when it works:
eth1: flags=4227<UP,BROADCAST,NOARP,MULTICAST> mtu 1460
inet 10.108.1.4 netmask 255.255.255.248 broadcast 10.108.1.7
inet6 fe80::480d:8072:565e:686c prefixlen 64 scopeid 0x20
ether a6:05:e1:3f:34:08 txqueuelen 1000 (Ethernet)
RX packets 12 bytes 2601 (2.5 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 30 bytes 4528 (4.4 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
output from the AT command LTEINFO
!LTEINFO: ^M
Serving: EARFCN MCC MNC TAC CID Bd D U SNR PCI RSRQ RSRP RSSI RXLV^M
8115 310 120 31344 0340460B 25 2 2 -1 385 -14.9 -118.0 -89.1 6^M
^M
IntraFreq: PCI RSRQ RSRP RSSI RXLV^M
386 -14.8 -120.4 -96.7 6^M
409 -14.8 -120.4 -96.7 6^M
411 -17.4 -125.5 -96.6 6^M
^M
InterFreq: EARFCN ThresholdLow ThresholdHi Priority PCI RSRQ RSRP RSSI RXLV^M
8763 0 4 1 385 -12.1 -107.2 -86.2 14^M
8763 0 4 1 386 -19.5 -114.7 -86.2 7^M
^M
WCDMA: UARFCN ThreshL ThreshH Prio PSC RSCP ECN0 RXLV^M
