I updated my FX30S with firmware 3.1.0.
The virtual ressource configuration generate an error:
CONFIG
“ID01”: {
“dt”: 4,
“v”: [
“B9C6769A”,
“B9EF769B”
ERROR
"ID01:JSON virtual resource config value must be a JSON Object"
CONFIG
“ID01”: {
“dt”: 4,
“v”: [
“B9C6769A”,
“B9EF769B”
ERROR
Hi @romuald
The format JSON is incorrect.
Please correct it as follows:
{“ID01”: {
“dt”: 4,
“v”: [
“B9C6769A”,
“B9EF769B”
Please help to tick “Solutions” if your question is answered.
My complete configuration is :
"ID01": {
"dt": 4,
"v": [
"B9C6769A",
"B9EF769B"
"codeIdReceive": {
"dt": 3,
"v": ""
"delay_barriere0": {
"dt": 2,
"v": 5
"delay_barriere1": {
"dt": 2,
"v": 5
"delay_barriere2": {
"dt": 2,
"v": 5
"delay_barriere3": {
"dt": 2,
"v": 5
"delay_barriere4": {
"dt": 2,
"v": 5
"tF_barriere0": {
"dt": 2,
"v": 0
"tF_barriere1": {
"dt": 2,
"v": 0
"tF_barriere2": {
"dt": 2,
"v": 0
"tF_barriere3": {
"dt": 2,
"v": 0
"tF_barriere4": {
"dt": 2,
"v": 0
Is it ok for you ?
Romuald
I confirm this configuration doesn’t work from firmware 3.1.0.
Hi @romuald
Each Resource is of a particular data type which can be a trigger, boolean, numeric, string, or JSON.
“ID01”: {
“dt”: 4,
“v”: {
“id1”: “B9C6769A”,
“id2”: “B9EF769B”
“codeIdReceive”: {
“dt”: 3,
“v”: “”
“delay_barriere0”: {
“dt”: 2,
“v”: 5
“delay_barriere1”: {
“dt”: 2,
“v”: 5
“delay_barriere2”: {
“dt”: 2,
“v”: 5
“delay_barriere3”: {
“dt”: 2,
“v”: 5
“delay_barriere4”: {
“dt”: 2,
“v”: 5
“tF_barriere0”: {
“dt”: 2,
“v”: 0
“tF_barriere1”: {
“dt”: 2,
“v”: 0
“tF_barriere2”: {
“dt”: 2,
“v”: 0
“tF_barriere3”: {
“dt”: 2,
“v”: 0
“tF_barriere4”: {
“dt”: 2,
“v”: 0
dt : 4 is JSON or Array.
It will be fix with the firmware 3.1.1
