I have trouble communicating with HL7810 on my MacBook laptop.
I just registered to Airvantage for first use.
HL7810 didn’t respond after I sent AT+CREG=5(5 is the wrong parameter. my mistake).
I did reconnect the cable to reboot, but not showing up in “/dev/tty.*”.
Could I H/W reset without AT communication?
how about connecting to Linux? (anything showing in dmesg?)
how about connecting to Windows?
Is there anything coming out in UART?
dmesg from Linux:
[10194644.620864] usb 5-1: new full-speed USB device number 10 using xhci_hcd
[10194644.847144] usb 5-1: New USB device found, idVendor=216f, idProduct=0051, bcdDevice= 0.00
[10194644.847151] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[10194644.847154] usb 5-1: Product: U-Boot 2012.10
[10194644.847156] usb 5-1: Manufacturer: Das U-Boot
[10194644.847158] usb 5-1: SerialNumber: 0000000
[10194644.900988] cdc_acm 5-1:1.0: ttyACM0: USB ACM device
[10194647.626073] usb 5-1: USB disconnect, device number 10
Nothing changes on Windows
For comparison, do you have another working HL7810 to connect to linux and Windows?
here is dmesg log with working HL7810
[10202244.619945] usb 5-1: new full-speed USB device number 13 using xhci_hcd
[10202244.837304] usb 5-1: not running at top speed; connect to a high speed hub
[10202244.854916] usb 5-1: New USB device found, idVendor=1199, idProduct=c001, bcdDevice= 0.00
[10202244.854921] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[10202244.854924] usb 5-1: Product: Sierra Wireless IoT Device
[10202244.854926] usb 5-1: Manufacturer: Sierra Wireless, Inc.
[10202244.854927] usb 5-1: SerialNumber: V1.00
[10202244.892999] cdc_acm 5-1:1.0: ttyACM0: USB ACM device
[10202244.895970] cdc_acm 5-1:1.2: ttyACM1: USB ACM device
[10202244.898974] cdc_acm 5-1:1.4: ttyACM2: USB ACM device
[10202244.901978] cdc_acm 5-1:1.6: ttyACM3: USB ACM device
strange that the VID and PID are different compared to previous one
I have two HL7810 devices.
- ID of the working device.
idVendor=1199, idProduct=c001, …
- ID of the not working device.(doesn’t respond after I’ve sent the wrong command)
idVendor=216f, idProduct=0051, …
I used the following method to download FW over USB in HL7800, not sure if you can recover your faulty module like this:
- AT+SWITRACEMODE=RnD → this is important as by default, there is no CLI port (just for any accident, you can still use AT command via CLI port)
- at+cfun=1,1
- AT+KUSBCOMP=1,1,2,3
- AT+CFUN=1,1
- Assume USB port enumerated are COM97 99 107 where COM 107 is the USB AT port
- double click the HL7800.4.4.13.0.exe
- choose 2 → USB(YMODEM)
- choose bootloader port COM96 (this might not be known at the first time running this program as when normal boot, you will not see this port)
- choose port to download as USB AT port which is COM107
