Reference: ADL User Guide for Open At v3.03, Rev 001, Dec 2005.
Just a little Gotcha! here:
The maximum block size is documented, but no minimum size is mentioned.
In fact, ADL_RET_ERR_PARAM (-2) is returned if the block size is zero.
Hmmm, why would you call a function to send data without anything to send?
Off topic: I guess that’s like starting a timer with interval 0. I did that once in an older version of OpenAT and sure enough it did crash the program which is worse than receiving an error
Best Regards,
Jan
That’s why I called it, “Just a little Gotcha!”
It’s a general case for sending strings - and, in the most general case, an empty string must be considered…
Of course, it’s easy enough to check the length first, and only call adl_fcmSendData if there’s >0 bytes to send.
One might hope that adl_fcmSendData would do that internally, but hey - there are far more pressing issues that need attention!
Just thought I’d note it here for reference.
Hi awneil,
I guess you are right… And it really should be documented clearly what the function does / returns on the possible inputs. Since the data is passed via pointer it should also be mentioned what the function will do / what the error code is if a NULL pointer is passed…
Best Regards,
Jan
Absolutely!
This should be the benchmark for all documentation!
Ooo-Errr - I haven’t tried that one…!
