This code is based off the given wip tcp client over gprs example.
void email_point() {
TRACE (( 1, "email_point" ));
wip_channel_t socket;
wip_debug( "[SAMPLE]: connecting to client %s:%i...\n", PEER_STRADDR, PEER_PORT);
socket = wip_TCPClientCreate( PEER_STRADDR, PEER_PORT, evh, NULL);
if( ! socket) { wip_debug( "[SAMPLE] Can't connect\n"); return; }
/* buffer to hold the data I want to send*/
static u8 snd_buffer[SND_BUFFER_SIZE];
/* How many bytes of [buffer] have already been sent. */
static int snd_offset = 0;
static char rcv_buffer[RCV_BUFFER_SIZE];
static int rcv_offset = 0;
/* Function : evh_data */
/* Object : Handling events happenning on the TCP client socket. */
/* Variable Name |IN |OUT|GLB| Utilisation */
/* ev | X | | | WIP event */
/* ctx | X | | | user data (unused) */
static void evh( wip_event_t *ev, void *ctx) {
TRACE (( 1, "Email EVH" ));
enum State {rts_Helo,
rts_Mail_From,
rts_RCPT_To,
rts_DATA,
rts_MSG,
cts_Helo,
cts_Mail_From,
cts_RCPT_To,
cts_DATA,
cts_MSG,
done,
error
static enum State state = rts_Helo;
switch( ev->kind) {
case WIP_CEV_OPEN: {
wip_debug ("[SAMPLE] Connection established successfully\n");
state = rts_Helo;
break;
case WIP_CEV_READ: {//data has arrived to be read
switch(state)
case rts_Helo:
//read whatever is on the socket and ensure the first chars are 220
read(ev, ctx);
if( rcv_offset > 4 && rcv_buffer[0] == '2' && rcv_buffer[1] == '2' && rcv_buffer[2] == '0')
rcv_offset = 0;
state = cts_Helo;
break;
case rts_Mail_From:
//read whatever is on the socket and ensure the first chars are 250
read(ev, ctx);
if( rcv_offset > 4 && rcv_buffer[0] == '2' && rcv_buffer[1] == '5' && rcv_buffer[2] == '0')
rcv_offset = 0;
state = cts_Mail_From;
break;
case rts_RCPT_To:
read(ev, ctx);
rcv_offset = 0;
state = cts_RCPT_To;
break;
case rts_DATA:
read(ev, ctx);
rcv_offset = 0;
state = cts_DATA;
break;
case rts_MSG:
//read whatever is on the socket and ensure the first chars are 354
read(ev, ctx);
if( rcv_offset > 4 && rcv_buffer[0] == '3' && rcv_buffer[1] == '5' && rcv_buffer[2] == '4')
rcv_offset = 0;
state = cts_MSG;
break;
default:;//do nothing
break;
case WIP_CEV_WRITE: {
switch(state)
case cts_Helo:
TRACE (( 2, "Send Helo" ));
JP_strncpy(snd_buffer, "Helo telus.net\r\n", SND_BUFFER_SIZE);
if(write(ev, ctx))
snd_offset = 0;
state = rts_Mail_From;
break;
case cts_Mail_From:
TRACE (( 2, "Send Mail from:" ));
char * temp = "MAIL FROM: ";
u16 temp_len = JP_strlen(temp);
JP_strncpy(snd_buffer, temp, SND_BUFFER_SIZE);
JP_strncpy(snd_buffer + temp_len, "do_not_reply@temp.com\r\n", SND_BUFFER_SIZE-temp_len);
if(write(ev, ctx))
snd_offset = 0;
state = rts_RCPT_To;
break;
case cts_RCPT_To:
TRACE (( 2, "Send RCPT TO:" ));
char * temp = "RCPT TO: ";
u16 temp_len= JP_strlen(temp);
JP_strncpy(snd_buffer + temp_len, recipient_, SND_BUFFER_SIZE-temp_len);
temp_len= JP_strlen(snd_buffer);
JP_strncpy(snd_buffer + temp_len, "\r\n", SND_BUFFER_SIZE-temp_len);
if(write(ev, ctx))
snd_offset = 0;
state = rts_DATA;
break;
case cts_DATA:
JP_strncpy(snd_buffer, "DATA\r\n", SND_BUFFER_SIZE);
if(write(ev, ctx))
snd_offset = 0;
state = rts_MSG;
break;
case cts_MSG:
char * temp;
u16 temp_len = 0;
if(subject_)
temp = "Subject:";
JP_strncpy(snd_buffer + temp_len, subject_, SND_BUFFER_SIZE-temp_len);
JP_strncpy(snd_buffer + temp_len, "\r\n\r\n", SND_BUFFER_SIZE-temp_len);
JP_strncpy(snd_buffer + temp_len, msg_, SND_BUFFER_SIZE-temp_len);
JP_strncpy(snd_buffer + temp_len, "\r\n.\r\nQUIT\r\n", SND_BUFFER_SIZE-temp_len);
if(write(ev, ctx))
snd_offset = 0;
state = done;
wip_close( ev->channel);
done_sending();
break;
break;
case WIP_CEV_ERROR: {
wip_debug( "[SAMPLE] Error %i on socket. Closing.\n",
ev->content.error.errnum);
state = error;
break;
case WIP_CEV_PEER_CLOSE: {
wip_debug( "[SAMPLE] Connection closed by peer\n");
state = error;
break;
static void read(wip_event_t *ev, void *ctx)
int nread;
wip_debug ("[SAMPLE] Some data arrived\n");
nread = wip_read( ev->channel, rcv_buffer + rcv_offset,
sizeof( rcv_buffer) - rcv_offset);
if( nread < 0) { wip_debug( "[SAMPLE] read error %i\n", nread); return; }
TRACE (( 3, (rcv_buffer + snd_offset) ));
rcv_offset += nread;
if( rcv_offset == sizeof( rcv_buffer)) {
wip_debug( "[SAMPLE] Reception capacity exceeded, won't read more\n");
} else {
wip_debug( "[SAMPLE] Wrote %i bytes of data from network to rcv_buffer. "
"%i bytes remain available in rcv_buffer\n",
nread, sizeof( rcv_buffer) - rcv_offset);
static bool write(wip_event_t *ev, void *ctx)
TRACE (( 3, (snd_buffer + snd_offset) ));
int nwrite;
wip_debug ("[SAMPLE] Can send more data\n");
nwrite = wip_write( ev->channel, snd_buffer + snd_offset,
JP_strlen(snd_buffer) - snd_offset);
if( nwrite < 0) { wip_debug( "[SAMPLE] write error %i\n", nwrite); return; }
snd_offset += nwrite;
if( snd_offset == JP_strlen( snd_buffer)) {
wip_debug( "[SAMPLE] Everything has been sent, won't send more.\n");
snd_offset = 0;
return TRUE;
} else {
wip_debug( "[SAMPLE] Wrote %i bytes. "
"%i bytes left to send in snd_buffer\n",
nwrite, sizeof( snd_buffer) - snd_offset);
return FALSE;
The Trace returns the following:
1188.182 Trace 1 internet_connection : Main
1188.698 Trace 1 (cfg_gprs) Enter.
1188.964 Trace 1 (evh_sim) Enter.
1218.977 Trace 1 (evh_sim) Enter.
1219.134 Trace 1 (poll_creg_callback) Enter.
1219.150 Trace 1 (poll_creg_callback) Registered on GPRS network.
1219.165 Trace 1 (open_and_start_bearer) Enter.
1221.680 Trace 1 Unable to find the string of the remote trace in the file (ID = 528)
1223.008 Trace 1 email_point
1250.881 Trace 1 Email EVH
1252.221 Trace 1 Email EVH
1254.222 Trace 1 Email EVH
1254.299 Trace 3 220 priv-edtnaa12.telusplanet.net ESMTP
1353.643 Trace 1 Email EVH
1371.440 Trace 1 Email EVH
The ev->kind are : open, write, read. read(timeout message). error.
So I get the msg that I’ve succesfully connected, but then I never get another chance to send data, so the connection times out. If anyone knows what I’m doing wrong I’d greatly appreciate the help.
In particular I’d like to know what triggers the call of the evh( wip_event_t *ev, void *ctx); function.
