UDP Broadcast
I need to set the socket to broadcast mode, when I try and send to 255.255.255.255 I am unable to capture any packets from my FastTrack Supreme. I have been though the WIP options but could find anything obvious, does any one know if this is possible.
What are you using to “capture” the packets?
Are you sure that your GSM provider allows UDP Broadcast?
Sorry, I should have stated I am using the LAN adapter module and sending a broadcast as part of a discovery process to detect devices on my local network.
