I tried to use the serial port (UART1) on the DevBoard, but i can’t even open the file /dev/ttys1.
Indeed, the function
open("/dev/ttys1", O_RDWR | O_NOCTTY | O_NDELAY)
returns the following error
open failed with errno 2 (No such file or directory)
In the /dev directory, the file “ttys1” (lowercase ‘s’) is enumerated and not “ttyS1” (uppercase ‘s’). Although, just to make sure, i tried to open both of them and the same error occurs.
How can I open the file corresponding to the serial port on UART1 ?
There are no character devices with a major node of 4 and a minor node of 64(or greater) which is where the traditional serial ports (ttyS0 etc) are located. the ttys0 node you’re trying is a pseudo-tty device and may not even be physically present…
There’s a few posts in mailing lists indicating that ttyHSL0 is mapped to the console in some adb/android devices … so I would look at trying to open ttyHSL0 (UART0) and ttyHSL1 (UART1) - just watch that you don’t clobber the serial console when opening ttyHSL0.
David is right. ttyHSL0 is actually UART1 on the dev kit and is normally allocated to be the console. ttyHSL1 is UART2 on the dev kit. They are the only 2 available on this chipset.
You can find out a lot about the peripherals by looking at the BSP test report spreadsheet that is included with the Yocto source bundle we provide. It has test procedures for exercising the various peripherals. If you don’t have the Yocto source bundle and don’t want to download it let me know and I’ll put it somewhere for you.
If you did, and you don’t have permissions to access it, then we may have a bug there. If you can detail what you did then I can have the guys here have a look at it. In the meantime, you can always directly modify permissions on the target as you have root access - just remember what you did so that you can undo it again.
COMPONENT_INIT
// Open the serial port.
int fd1 = open("/dev/ttyHSL1", O_RDWR|O_NONBLOCK);
LE_ERROR_IF(fd1 == -1, "HSL1 open failed with errno %d (%m)", errno);
Each app has its own user ID and primary group ID. User name and primary group name is “app-xxxx”, where the “xxxx” is replaced with the name of the app.
Sandboxed apps aren’t allowed to be members of other groups and are not allowed to have any capabilities (see “man 7 capabilities”) set on their executables.
Unsandboxed apps are allowed to have executables with capabilities and be members of other groups (see the “groups:” section).
So using the .adef example from John, include a groups: section and add ‘dialout’
I’m (trying) using Dev Studio. I tried adding groups yesterday to the .adef but the Dev Studio tool:
Doesn’t have groups (actually it doesn’t have sandboxed …) in its section selection
I manually hacked groups into the .adef file - but when I open the .adef in Dev Studio the tool moans and messes up the .adef file - then the app won’t build due to the messed up .adef
Am I just seeing a bug in Dev Studio?
Did you build outside Dev Studio?
Do the .adef sections have to be in a particular order?
In a practical system:
Will the apps which talk to real hardware need to be outside sandboxes?
Will sandboxed apps be able to communicate with unsandboxed apps (I’m guessing not)?
We still have some troubles on the adef files editor (currently still working on it).
To avoid being annoyed by the editor, you can simply open the adef file in the text editor (Right Click Menu > Open With > Text editor)
Improvements on that are coming with DS 3.1
As for the error editting the .adef file, it seems like it’s an issue with the current DS3 parser. To workaround this issue, please follow the suggestion provided by daav.
I have normal access to ttyHSL1, currently in use as debug port (UART2), but no HSL0 is shown in my /dev.
Is there any AT command I must perform to make it visible? Or it’s hidden somewhere?
hii…
I have started wrking on the AR-WP series development kit .
I went through the user guide . It says that to connect UART 2 for the serial communication. I enables the UART2 ON and plugged . But i dint see any reply in serial console window .
Just fr cross verification i plugged to UART1 and enabled the UART1 ON , I could see the booting n poer on the kit i could see thebooting sequence .
Kindly help me out which is correct to wrk with . in all the manuals they have mentioned UART 2 only
