Thank you for your answer ,
i use the qt2787 , i have tis error in the function adl_OpenDevice(DF_UART_CLID, &Settings);
I can not retrieve the Hadler of the prgramme because it stop when it comes to this function
i tried with at+wmfm=0,1,2 but i have the same error.
errors :
Trace HWL 1 ARM Data Abort caught at 00056B50, Current Task 0x01 by CP15
Trace RTK 1 ================== RTK STATUS start ==================
Trace RTK 1 ================== RTK STATUS end ==================
Trace SYS 1 Unable to find the string of the remote trace in the file (ID = 5877)
Trace SYS 1 Unable to find the string of the remote trace in the file (ID = 5878)
My programe :
#include “adl_global.h”
#include “wm_uart.h”
/ Local variables /
static psGItfCont_t s_g_uart_itf;
static s32 s_g_uart_handle;
/ Mandatory variables /
/ wm_apmCustomStackSize /
// Verification de la version de l’api
#if OAT_API_VERSION >= 400
const unsigned short wm_apmCustomStackSize = 4096;
#else
unsigned long wm_apmCustomStack[1024];
const unsigned short wm_apmCustomStackSize = sizeof(wm_apmCustomStack);
#endif
/ Function : adl_main /
/ Object : Customer application initialisation /
/ Variable Name |IN |OUT|GLB| Utilisation /
/ InitType | | | | Application start mode reason /
TRACE (( 1, “Embedded Application : Main” ));
sUartSettings_t Settings;
sUartLc_t line_coding;
psGItfCont_t pCont = &s_g_uart_itf;
/* Line Coding */
line_coding.valid_fields = UART_LC_ALL;
line_coding.rate = (eUartRate_t)(UART_RATE_USER_DEF | 57600 );
line_coding.stop = UART_STOP_BIT_1;
line_coding.parity = UART_PARITY_NONE;
line_coding.data = UART_DATALENGTH_8;
/* Device */
Settings.identity = “UART2”;
Settings.event_handlers = NULL;
//Settings.interface = &pCont;
Settings.interface = &s_g_uart_itf;
Settings.role = UART_ROLE_NM;
Settings.line_coding = &line_coding;
Settings.capabilities=NULL;
s_g_uart_handle=adl_OpenDevice(DF_UART_CLID, &Settings);
TRACE(( 1, “s_g_uart_handle (%d)”, s_g_uart_handle));
Thank you !
