Troubleshooting +CME ERROR: 921 during HTTPS POST on HL7800
Hi Support!
I’m trying to create a HTTPS POST to https://api.sandbox.ewaypayments.com/ using a HL7800 chip with the latest firmware BHL7800.3.7.2.3.20191030.
I’m getting an +CME ERROR: 921 when I go to add the POST body, which means Error due to invalid state of bearer connection.
How can I resolve this issue? Thanks for your help!
AT logs below:
AT
ATI3
AT+CMEE=1
AT+CPIN?
+CPIN: READY
AT+CGATT=0
AT+CREG?
+CREG: 0,0
AT+CEREG?
+CEREG: 0,0
AT&K3
AT+KPATTERN="--EOF--Pattern--"
AT+KCERTDELETE=0,0
AT+KCERTDELETE=1,0
AT+KCERTDELETE=1,1
AT+KCERTDELETE=1,2
AT+KPRIVKDELETE=0
AT+KPRIVKDELETE=1
AT+KPRIVKDELETE=2
AT+KSSLCFG=0,3
AT+KSSLCFG?
+KSSLCFG: 0,3
+KSSLCFG: 2,0
AT+KCERTSTORE=0
CONNECT
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
AT+KCERTSTORE?
CONNECT
root_cert,0,1294
-----BEGIN CERTIFICATE-----MIIDjjCCAnagAwIBAgIQAzrx5qcRqaC7KGSxHQn65TANBgkqhkiG9w0BAQsFADBhMQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3d3cuZGlnaWNlcnQuY29tMSAwHgYDVQQDExdEaWdpQ2VydCBHbG9iYWwgUm9vdCBHMjAeFw0xMzA4MDExMjAwMDBaFw0zODAxMTUxMjAwMDBaMGExCzAJBgNVBAYTAlVTMRUwEwYDVQQKEwxEaWdpQ2VydCBJbmMxGTAXBgNVBAsTEHd3dy5kaWdpY2VydC5jb20xIDAeBgNVBAMTF0RpZ2lDZXJ0IEdsb2JhbCBSb290IEcyMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAuzfNNNx7a8myaJCtSnX/RrohCgiN9RlUyfuI2/Ou8jqJkTx65qsGGmvPrC3oXgkkRLpimn7Wo6h+4FR1IAWsULecYxpsMNzaHxmx1x7e/dfgy5SDN67sH0NO3Xss0r0upS/kqbitOtSZpLYl6ZtrAGCSYP9PIUkY92eQq2EGnI/yuum06ZIya7XzV+hdG82MHauVBJVJ8zUtluNJbd134/tJS7SsVQepj5WztCO7TG1F8PapspUwtP1MVYwnSlcUfIKdzXOS0xZKBgyMUNGPHgm+F6HmIcr9g+UQvIOlCsRnKPZzFBQ9RnbDhxSJITRNrw9FDKZJobq7nMWxM4MphQIDAQABo0IwQDAPBgNVHRMBAf8EBTADAQH/MA4GA1UdDwEB/wQEAwIBhjAdBgNVHQ4EFgQUTiJUIBiV5uNu5g/6+rkS7QYXjzkwDQYJKoZIhvcNAQELBQADggEBAGBnKJRvDkhj6zHd6mcY1Yl9PMWLSn/pvtsrF9+wX3N3KjITOYFnQoQj8kVnNeyIv/iPsGEMNKSuIEyExtv4NeF22d+mQrvHRAiGfzZ0JFrabA0UWTW98kndth/Jsw1HKj2ZL7tcu7XUIOGZX1NGFdtom/DzMNU+MeKNhJ7jitralj41E6Vf8PlwUHBHQRFXGU7Aj64GxJUTFy8bJZ918rGOmaFvE7FBcf6IKshPECBV1/MUReXgRPTqh5Uykw7+U0b6LJ3/iyK5S9kJRaTepLiaWN0bfVKfjllDiIGknibVb63dDcY3fe0Dkhvld1927jyNxF1WW6LZZm6zNTflMrY=-----END CERTIFICATE-----
local_cert,0,0
local_cert,1,0
local_cert,2,0
AT+CCLK?
+CCLK: "19/12/17,07:06:11+44"
AT+KCNXCFG=1,"GPRS","telstra.wap","",""
AT+KCNXPROFILE=1
AT+KSSLCRYPTO=0,9,3,25456,12,4,1
AT+KCNXUP=1
+KCNX_IND: 1,4,1
+KCNX_IND: 1,2,1,2,30
AT+KHTTPCFG=1,"api.sandbox.ewaypayments.com",443,2,,,,,0
+KHTTPCFG: 1
+KCNX_IND: 1,4,1
AT+KHTTPHEADER=1
CONNECT
Host: api.sandbox.ewaypayments.com
Accept: */*
Accept-Encoding: gzip, deflate
Content-Type: application/json
Content-Length: 214
Connection: keep-alive
Authorization: Basic NjBDRjNDZTk3blJTMVoxV3A1bTlrTW16SEhFaDhSa3VqMzFRQ3RWeGpQV0dZQTlGeW15cXNLMEVubTFQNm1ISmYwVEhiUjpBUEktUDRzcw==
--EOF--Pattern--
AT+KHTTPPOST=1,,"/DirectPayment.json",1
**+CME ERROR: 921**
**+KCNX_IND: 1,4,1**
**+KCNX_IND: 1,2,1,2,30**
AT+CGATT=0
AT+KCNXUP=1
+KCNX_IND: 1,4,1
AT+KHTTPCFG=1,“api.sandbox.ewaypayments.com”,443,2,0
+KHTTPCFG: 1
+KCNX_IND: 1,4,1
AT+KHTTPPOST=1,“/DirectPayment.json”,1
+CME ERROR: 921
+KCNX_IND: 1,4,1
The HL7800 cannot bring up PDP connection after network detachment in your log file. It has not supported this behavior. So you should remove AT +CGATT=0 command.
Here is result on my module:
+KHTTP_IND: 1,1
CONNECT
NO CARRIER
+KHTTP_ERROR: 1,6
Please find the log file for your reference.KHTTPPOST_api.sandbox.ewaypayments.com.txt (2.8 KB)
For issue NO CARRIER, +KHTTP_ERROR: 1,6 after KHTTPPOST with api.sandbox.ewaypayments.com server. It does not work for headers that may contain many fields. It can be limitation of the current firmware module. I hope new firmware release will be updated to fix the issue.
