EM7455 in Lede/OpenWRT with a TMobile SIM.
SIM is good, I confirmed with carrier and I can switch it to a tablet and I get data.
Board/OS is good, I can connect fine with Sprint when I’m on the correct Sprint at!band in QMI mode.
Here’s my AT!GSTATUS?
!GSTATUS:
Current Time: 1621 Temperature: 32
Reset Counter: 11 Mode: ONLINE
LTE band: B2 LTE bw: 15 MHz
LTE Rx chan: 1025 LTE Tx chan: 4294967295
LTE CA state: NOT ASSIGNED
EMM state: Registered PLMN Search
RRC state: RRC Idle
IMS reg state: No Srv
PCC RxM RSSI: -80 RSRP (dBm): -118
PCC RxD RSSI: -96 RSRP (dBm): -140
Tx Power: 0 TAC: 3404 (13316)
RSRQ (dB): -19.1 Cell ID: 0AB7DE08 (179822088)
SINR (dB): -6.0
It shows registered and attached, but EMM says Registered PLMN Search
Other commands:
at+cgdcont?
+CGDCONT: 1,“IP”,“fast.t-mobile.com”,“0.0.0.0”,0,0,0,0
at+cgcontrdp
+CGCONTRDP: 1,5,fast.t-mobile.com,100.79.224.223,10.177.0.34,10.177.0.210
at!band?
Index, Name, GW Band Mask L Band Mask TDS Band k
0E, TMobile, 0000000000000000 000000000000080A 0000000000
(This is bands 12, 4, and 2)
at!usbcomp=1,1,10d
(QMI Mode)
uqmi shows the IP/Gateway/DNS, and I made sure /sys/class/net/wwan0/qmi/raw_ip is Y
I set up my wwan0 IP addr in raw_ip mode, and the default gateway through route.
I can’t ping or get any data, though.
This same device works with a Sprint SIM, when I’m on the correct Sprint AT!band. I’m just getting nothing for TMobile, and the only difference I see is that PLMN Search on the EMM line of GSTATUS.
Any ideas of what to check?
