Hy guys, i have an application wich receives some data on a TCP/IP socket, then forwards that data on the UART1, takes a response and forwards this response back on GRPS.
It seems that the transfer is pretty slow. Do you have any ideea how can i speed this up? i mean, should i use interrupts at WIP_CEV_READ/WRITE, so the process can handle only the data transfer?
I tried to play with channels options for raising the buffer sizes, but it seems that the application sending the requests on GRPS send a request, then waits for a response and then sends another request. It’s not a matter of how much data, it’s a matter of how quickly can i make the transfer.
I hope i was clear enough, if any can give me a hint!
Thanks in advance…
