Good morning,
I use the Q2686H and I have a problem. I have to open a TCP/IP socket, send multiple transmissions (HTTP protocol) and then close it when finished. The broadcasts consist in sending 700 bytes and receiving in response 235 bytes, so on for “n” times.
Currently I can send only 1 transmission (TX + RX) and then socket closes. Event handler returns a WIP_CEV_PEER_CLOSE even if I try to write again data through socket ( wip_write() ).
I looked in manual and I also tried the socket opening with KEPPALIVE and NODELAY parameters with no success.
My development environment is: Q2686H, OpenAT v 4:24:00, WIP Open AT IP v 3.10, FW v 663f00
Can you help me?
Thank you very much.
Manlex
