Hello…
I am using the WIP plug in to create a TCP client connection. The problem I am facing is that when the client disconnects the TCP server is not notified (which is really a problem for my application)… I tried using wip_shutdown() function as well as wip_abort() before using wip_close() but although they return 0 (success) the server is not notified that the client is disconnected… There is no problem on the server side (when I use HyperTerminal, for example, as the TCP client the server is notified when the client is disconnected).
In the wip_abort() and wip_shutdown() documentation it is mentioned that both functions cause an error at the peer socket but I receive no such error on the server side…
Any hints would be appreciated…
Thanks a lot…
George Savidis
