I would like to manage a double sim, so that I can switch between two different operators, i.e. when the signal is too low.
In order to to that I used a switch that moves the SIM-IO and the SIMPRES IO from one sim to the other.
The switch can be managed by a gpo.
If I switch the SIM the modem cannot realize that something actually changed, and sometimes crashes.
It seems that, although I use the SIMPRESS directly (or drived by a gpo, in series after the simpress wire ) the modem realize that one sim is present, regardless by the value of the simpress itself.
How the modem realize that a sim is inserted and when is removed? (ADL_SIM_EVENT_INSERTED and ADL_SIM_EVENT_REMOVED events)?
I think that I need to “switch off” the sim, switch the SIM-IO and the SIMPRESS on the other sim and then “switch on” the sim. Is there any AT command that let me force the reinit of a sim, without resetting the modem?
Are you simply switching SIMPRES between the two SIMs, or are you forcing it low for some amount of time? I assume that if SIMPRES was forced low for a while before connecting it to the new SIM, then the Q2686 would just think you phisically swapped SIM cards.
Rather than just guess how long might be needed for “for a while”, why not wait for the “SIM Removed” event, and only connect the other SIM after that?
Im having some trouble to do DUAL SIM. In mi case, im using the SIMPRESS driven with an 1.8V Output. But, unforntunaletly im always receiving a SIM STATE REMOVED.
Im using a Q2687H with the R74 Firm.
And my sequence is like this.
I detected one or two SIMS by two inputs.
I write in the 1.8Output a “1”.
I choose wich SIM i would to manage with an output (this manage all the hardware SIM selection).
I suscribe to the SIM services.
I receive a SIM STATE REMOVED.
I am doing something wrong??, i cant find any problems with the hardware. And i could find any documentation about this.
