Hello
I’m trying to run swiflash via command line on Windows. When I select the -p option to specify a port I get Unknown parameter "-p"
Running the help menu doesn’t display the -p option either. Is this available for Linux builds only?
Hello
Hi pavel.boev ,
Yes, it is.
swiflash - command line tool (linux host)
swiflash is a platform-specific tool used to flash images into WP/AR products through the USB port. This is a recovery tool that can be used even if the device is not booting anymore (due to corrupted configuration files in the root FS, badly customized Linux kernel or Legato framework, etc.).
You can refer to this link for more details
https://source.sierrawireless.com/resources/airprime/software/swiflash/#sthash.SQyS20nf.dpbs
Please help to mark “Solution” if your question is answered. So the community could easily find the solution for their problems.
