Hi all,
I encountered a strange behavior after I upgraded from 1.1.0 to 1.1.2 and also in 1.2.0 beta while using compiler directives.
I have the following example
test.h
#define TEST_MODE
test.c
void test(void) {
#ifdef TEST_MODE
adl_atSendResponse(ADL_AT_RSP,"test mode active");
#else
adl_atSendResponse(ADL_AT_RSP,"test mode inactive");
#endif
in M2MStudio 1.1.0 if I have the compiler definition and do a build I get a dwl witch is showing the message “test mode active” and if I comment the definition in test.h, save the change and compile it again I get to new version witch shows the message “test mode inactive”.
Now in version 1.1.2 and the new 1.2 beta version if I do the same steps as in 1.1.0 the version with the definition active is compiled and get the “test mode active” but after I comment the definition in test.h file, save it and a build I get the message “Nothing to build”. But there is a “major” change in how the new dwl will behave.
Any ideas on how to solve this issue/bug because I have a modular application witch share the same core code and I do not want to split the project in 2 or more projects because I will have to change them all if I do some new features or change old ones.
