Hello All.
I am having a problem with the SPI interface of Q2501B.
Basically when I send or received more than 520 bytes, the module freezes.
To simulate the problem, just create a Handler for SPI Bus and run the following instruction:
Hello Odilon, you may check how your buffer is declared.
If “buffer” location is in your Open AT stack memory, you also may need to increase the default stack size set to 256 bytes that may not be enough for what you are trying to do?
Thanks for your help DeleteAll.
I changed u32 wm_apmCustomStack to 512, 1024, 2048 … without success. I also verified the “buffer” arrays and it is OK, with 600 bytes.
To contour the problem, I’m accessing the SPI Bus with values below 520 bytes, through multiples requests. This procedure fixed the problem.
For hardware interfaces (IOs, buses, …), flash memory storage and time critical tasks, I suggest you to use the TARGET mode instead of the REMOTE mode.
You can add traces in your source code to debug in TARGET mode.
