I want to write datas in external storage through SPI1. I used the sample code which is in OpenAT. But I can’t read & write in it. The below are my SPI bus settings,
adl_busSPISettings_t MySPIConfig =
9, // use 1.3MHZ clock speed 112
ADL_BUS_SPI_CLK_MODE_1, // Mode 0 clock
ADL_BUS_SPI_ADDR_CS_GPIO, // Use a GPIO to handle the Chip Select signal
ADL_BUS_SPI_CS_POL_LOW, // Chip Select active in low state
ADL_BUS_SPI_MSB_FIRST, // Data are sent MSB first
ADL_IO_GPIO | 31, // Use GPIO 35 to handle the Chip Select signal
ADL_BUS_SPI_FRAME_HANDLING, // LOAD signal not used
ADL_BUS_SPI_DATA_UNIDIR, // 3 Wires configuration
ADL_BUS_SPI_MASTER_MODE, // Master mode
ADL_BUS_SPI_BUSY_UNUSED // BUSY Signal Used
Is there anyone succeed it before. Thanks in Advance.
SPI can be tricky. Have you got a CRO (oscilloscope) to watch the SPI I/O lines? By preference, a four channel CRO is appropriate - you really need to watch CS, SCK, SDI and SDO. Trigger off CS going negative, then manually decode the first few bytes so you know what’s being sent by the Q26 and what’s being returned by the external storage.
Blindly using the settings from the ADL example can be a trap.
Do you know what mode your SPI external memory chip uses? SPI can be set to one of four different modes.
Have you got the hardware set up properly? SCK goes to SCK, but Q26 SDI goes to Memory SDO; Q26 SDO goes to Memory SDI… As Madouc said, check that your CS line is correct. In my experience, Flash chips are selected when CS is LOW - but check your datasheet to ensure that this is the case.
Software: Check your Mode, and that you are using the correct GPIO for CS (your code indicates you are using GPIO 31, the comment says GPIO 35. Which is correct?). Have you set up a adl_busAccess_t structure correctly?
Write a short program to simply try and read the status register of your Flash Chip. Watch the transfer on the CRO.
Really, get hold of a CRO and watch the hardware I/O pins. It’s the only way to get this right…
