SPI Bus interface using Q24x6 or Q2501B or New Q24
"How to connect a 4-wire SPI salve to a 3-wire SPI master interface on the Q24 module? "
I am in need of some help with this. I am trying to connect a microcontroller which has 4 WIRE (MISO,MOSI,SCL,SS) for SPI and I would like to connect this as SLAVE to Q24 Module which will always work only as SPI MASTER. I would greatly appreciate if you can share some ideas both hardware & software. Few pieces of code to receive data alone would do, since the Micro controller will always be transmitting and Q24 will be always receiving at regular interval.
Thanks in advance.
Green
