I am sure that I am missing something quite simple, but could you tell me how to bring the Simple TCP Client example into Developer Studio and build it. Maybe I need a step by step guide or something.
I seem to be having problems with the WIP library, but when I try to connect to it. I set up the include path which seems to work fine, but for the library itself I get the following:
Description Resource Path Location Type
Link error: Software\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.43.3.201212250709_5.43.3.201212250709\resources\WIP\ARM_ELF_GCC_WIP.lib: No such file or directory testClient C/C++ Problem
Link error: Wireless\Embedded: No such file or directory testClient C/C++ Problem
Link error: Software\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.43.3.201212250709_5.43.3.201212250709\resources\WIP\ARM_ELF_GCC_WIPSoftLib.lib: No such file or directory testClient C/C++ Problem
Link error: Files\Sierra: No such file or directory testClient C/C++ Problem
I moved the libraries to a shorter path name to see better what was going on and I get this:
Link error: cannot find -lD:\SWworkspace\WIP\ARM_ELF_GCC_WIP.lib testClient C/C++ Problem
This appears to have a problem with the -l not being separated from the library location.
Any help will be appreciated.
