Which AT commands do you need? i keep getting bad session id errors.
AT+KMQTTCFG=1,0,“test.mosquitto.org”,1883,3,1
AT+KMQTTCNX=1
AT+KMQTTSUB=1,“Publish”,0
AT+KMQTTPUB=1,“Publish”,0,0,“TEST”
AT+KMQTTCNX=1
which module are you using?
Which FW are you using?
i saw that other user can make it work:
Yes i see,
But this example uses Amazon Web Services which i don’t want to use and uses encryption&Authentication which i want to use in the future but not now.
So i will not need certificates.
Using the reference guide it says to give the following AT command:
But this also isn’t working.
Do you maybe have another example for just using MQTT AT commands?
Or do you know what commands i need before it should work?
Thanks in advance! ![]()
I don’t see problem with the following:
at+kcnxcfg=1,"GPRS","iot.swir"
AT+KMQTTCFG=1,0,"test.mosquitto.org",1883,3,"hl78.1234",120,0,1,"test.hl78","network lost",0,0,"username","password"
+KMQTTCFG: 1
ati3
HL7812.5.4.12.1
