hkiol
March 11, 2021, 12:44pm
1
Hey,
I am trying to connect to an MQTT broker with SSL (HL7802 4.6.6) and the first command that i configure is:
AT+KCERTSTORE=0,1337,0
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
This returns +CME ERROR: 930 (Content of input data is invalid or not supported). So the length is supposedly correct. The certification is from here
This is the first step i think i should take for configuring SSL. Correct?
Then +KSSLCRYPTO and AT+KTCPCFG with secure client.
What am i missing?
thanks
jyijyi
March 11, 2021, 1:28pm
2
You need to use tera term with hardware flow control.
When you send the file in tera term, choose file → send file → click “binary” box" → choose the cert to send.
in module, type
AT&k3
AT+kcertstore=0
send attached cert.txt
cert.txt (1.3 KB)
at+kcertstore=0
CONNECT
at+kcertstore?
CONNECT
root_cert,0,1339
local_cert,0,0
local_cert,1,0
local_cert,2,0
hkiol
March 11, 2021, 2:18pm
3
jyijyi:
at+kcertstore?
I was using hardware flow control. It seems that it needed both a CR and the KPATTERN at the end and it works fine but with AT+KCERTSTORE=0,1339,0 (not 1337)
So this is inaccurate?
thanks
jyijyi
March 11, 2021, 2:31pm
4
You can just use AT+KCERTSTORE=0
hkiol
March 11, 2021, 2:33pm
5
And if i need multiple certs the command should look like this?: AT+KCERTSTORE=0, ,0
AT+KCERTSTORE=0, ,1
thanks
jyijyi
March 11, 2021, 3:02pm
6
Seems index can only be zero for root cert
