Hi All,
Have what I thought would be a simple use case, but having no luck. The goal is SMS intergration w/ SCOM system monitoring software. I already have this working with a Multitech systems modem, so I know it is possible. My current configuration is as follows: GL6100 connected via serial to Digi port server setup as virtual COM port on server.
What works:
Can connect to the virtual comm port on a linux box and successfully send SMS via gnokii, so I know that network and GSM provider setup is good
I can connect to the COM port on 2012r2 via Putty and send AT commands to the unit, so I know that virtual comm port setup is good
I can assign a generic modem to the comm port (this may not be the right way to go).
What doesn’t work:
I can’t get windows to send SMS using Microsoft SMS sender when pointed at the modem (can’t go straight to comm port) following setup method here:
blog.msvconsultancy.co.uk/2014/0 … scom-2012/
This does work for the old Multitech modem in a similar configuration
To be honest, I don’t know what series of commands SMS sender uses to send the SMS, but as far as I can tell it is the same thing that SCOM does as that fails as well.
So, any tips or suggestions on doing a simple SMS message from windows 2012r2? I haven’t found any modem drivers that might be more appropriate for this unit.
Many thanks,
-Richard
