Hi all,
I’m writing to spread some knowledge about a memory initialization problem in the QMI SDK 03.00.02 related to the ciipcchanfixedinfo array and the CIMAXIPCCHAN macro. When compiling for and running slqssdk on an ARM9 32-bit target, I saw the following in /var/log/syslog:
In running slqssdk through gdb, I was able to eventually discover that the ciinit() routine was clobbering the dlgcb struct used in dlregister(), corrupting the dlgcbp->dlpidcount member.
ciinit() attempts to initialize the cigcb struct. It is a simple loop that associates the cigcb.ciipcchanlist[].cichanfixedinfop member with a constant data set stored in the ciipcchanfixedinfo[] array.
The loop iterates based on the return value of cigetnumchannels(), which in turn uses the sizeof(array)/sizeof(array.element) compiler trick to “dynamically” calculate the number of elements in the ciipcchanfixedinfo array at compile time.
The cigcb.ciipcchanlist[] array member is statically initialized at compile time using the CIMAXIPCCHANNELS macro.
There is a mismatch in the number of elements defined in the “dynamic” array ciipcchanfixedinfo and the “static” array cigcb.ciipchanlist[]. This results in writing past the end of cigcb.ciipcchanlist[] and into the dlgcb memory region, resulting in the corruption mentioned earlier.
I cannot get this problem to reproduce on an x86 system, but have noticed odd behaviors on an amd64 system unless the gcc -m32 flag is used. It may be coincident or related. However, it is reliably reproducible on the ARM9 system. I think that this problem would affect all platforms, however.
Simply updating CIMAXIPCCHANNELS to match the number of elements in ciipcchanfixedinfo[] is one part of the solution. A second part would be to add CIMAXIPCCHANNELS to the array initializer for ciipcchanfixedinfo[] so that any discrepancies in the future would immediately show up at compile time:
I hope that this helps someone else in the future.
Chris
