anybody knows how to restart the modem with another command than CFUN=1? I ask this because when I restart with CFUN=1 the program restarts but the traces are not showed again in the target monitoring tool.
i don’t know if CFUN=1 is the perfect command to do a complete software restart.
When you are using the Target Monitoring Tool, if you send an AT+CFUN=1 command then you have to send the “Init Target” command to be able to see the traces again.
You can do this directly in the Terminal Emulator window using the shortcut :
