Hi
I’m using a Q2687 modem, and I want to restart the modem with an AT+CFUN=1 call from software. I’m currently checking the state of a pin. If the pin goes from low to high, the modem should restart but I get the following RTK error…
10/10/30,08:59:11:968 RTK 1 Except RTK …191 2 2
When the state of the pin changes, the function below is called. The state of the pin is checked with the ioReadSingle function. And depending on the state of the pin and the previous state, the modem must do a restart. But the RTK error keeps haunting me,no matter what I try.
Any help would be appreciated
void MyGpioEventHandler ( s32 GpioHandle, adl_ioEvent_e Event, u32 Size, void * Param ){
int waste;
s8 checker;
// Check event
switch ( Event )
case ADL_IO_EVENT_INPUT_CHANGED :
pin_state = adl_ioReadSingle (GPIO33_Handle, &GpioConfig_33 );
if((pin_state==1) && (prev_pin_state==0)){
if(Flashwrite_Handler(6)==0){
restart_now=1;
checker = adl_atCmdSend("CFUN=1",NULL);
}else{
prev_pin_state=pin_state;
break;
