For some of AT commands what is response time need to wait
commands like AT,AT+CSQ?,AT_+CREG,AT+CGATT ect
please see RC76xx AT command user guide- Section “A.3 Command Timeout and Other Information”:
https://source.sierrawireless.com/resources/airprime/software/rc76xx-at-command-reference-guide/#sthash.HIcRE0bm.dpbs
Thank you for Refering this section,with this i have query of for sending just at command ,i have to wait 2 second to get response as OK from gsm modem
this is just the maximum value for timeout
okay with minimum time how fast i can get response for AT command
I just tried in UART:
[2025-09-22 17:46:54.320] at
[2025-09-22 17:46:54.603] OK
[2025-09-22 17:46:55.449] ati3
[2025-09-22 17:46:55.877] Manufacturer: Sierra Wireless, Incorporated
[2025-09-22 17:46:55.877] Model: RC7620-1
[2025-09-22 17:46:55.877] Revision: SWI9X07H_00.09.10.00 85890e jenkins 2023/09/25 03:16:56
[2025-09-22 17:46:55.893] IMEI: 353635110212345
[2025-09-22 17:46:55.893] IMEI SV: 29
[2025-09-22 17:46:55.893] FSN: 7T118701512345
[2025-09-22 17:46:55.893] +GCAP: +CGSM
[2025-09-22 17:46:55.893] OK
from above reference its taking around 300 ms for getting response for AT command
is ther any possibility to get at command response in micro second
if you use USB AT port, the response will be faster:
[2025-09-24 12:21:31.934] at
[2025-09-24 12:21:32.066] OK
[2025-09-24 12:21:32.887] ati3
[2025-09-24 12:21:32.890] Manufacturer: Sierra Wireless, Incorporated
[2025-09-24 12:21:32.890] Model: RC7620-1
[2025-09-24 12:21:32.890] Revision: SWI9X07H_00.09.10.00 85890e jenkins 2023/09/25 03:16:56
[2025-09-24 12:21:32.890] IMEI: 353635110212435
[2025-09-24 12:21:32.890] IMEI SV: 29
[2025-09-24 12:21:32.890] FSN: 7T118701512345
[2025-09-24 12:21:32.890] +GCAP: +CGSM
[2025-09-24 12:21:32.890] OK
for USB port also its taking around 130 ms ,is it any way to read response in micro second
did you do any test on your side with USB port?
Tried again with tera term with USB port by directly pasting AT commands instead of typing manually:
[2025-09-24 12:39:39.962] AT
[2025-09-24 12:39:39.962] OK
[2025-09-24 12:39:40.780] at
[2025-09-24 12:39:40.780] OK
[2025-09-24 12:39:41.585] at
[2025-09-24 12:39:41.585] OK
[2025-09-24 12:39:42.398] at
[2025-09-24 12:39:42.398] OK
[2025-09-24 12:39:43.214] at
[2025-09-24 12:39:43.214] OK
Basically we are interface ths GSM modem with microcontroller through UART.in this interface i am unable to receive response in micro second
tried again on UART with tera term by directly pasting AT commands instead of typing manually
[2025-09-24 12:54:43.413] AT
[2025-09-24 12:54:43.413] OK
[2025-09-24 12:54:44.245] at
[2025-09-24 12:54:44.245] OK
[2025-09-24 12:54:45.028] at
[2025-09-24 12:54:45.045] OK
[2025-09-24 12:54:45.845] at
[2025-09-24 12:54:45.845] OK
[2025-09-24 12:54:46.661] at
[2025-09-24 12:54:46.661] OK
BTW, you might also need to increase UART baud rate (e.g. 921600) by AT+IPR command and see if there is any improvement.
this command was unable to find in data sheet
can u please refer datasheet for RC7620 gsm modem with all command included
AT+IPR is a standard command from 3GPP specification:
https://portal.3gpp.org/desktopmodules/Specifications/SpecificationDetails.aspx?specificationId=1515
RC76 AT command user guide will not include all the standard command usage, but you can have a look here:
okay Thank you. currently I’m using UDP packet transfer protocol. which are the essential command i need to check every time before sending data to server.
currently i am using AT+CSQ to check signal strength
AT+CREG? to check network registered to home or its roaming
AT+CGATT? for modem status attached with gprs
for me these commands taking near 1 second
here is my testing in UART:
[2025-09-25 12:43:04.046] AT+CSQ
[2025-09-25 12:43:04.046] +CSQ: 26,99
[2025-09-25 12:43:04.046] OK
[2025-09-25 12:43:04.864] AT+CREG?
[2025-09-25 12:43:04.864] +CREG: 2,1,"FFFE","16E8A17",7
[2025-09-25 12:43:04.864] OK
[2025-09-25 12:43:05.663] AT+CGATT?
[2025-09-25 12:43:05.663] +CGATT: 1
[2025-09-25 12:43:05.663] OK
[2025-09-25 12:44:17.307] at+CSQ;+CREG?;+CGATT?
[2025-09-25 12:44:18.044] +CSQ: 24,99
[2025-09-25 12:44:18.044] +CREG: 2,1,"FFFE","16E8A17",7
[2025-09-25 12:44:18.044] +CGATT: 1
[2025-09-25 12:44:18.044] OK
