Request for Guidance on 2G/3G/4G Network Testing on HL7812 EVK
We are currently testing the HL7812 EVK and would like your guidance on validating cellular network connectivity and data services. Our team is testing from Shanghai, China, where have live networks are available.
We have a few queries related to testing and configuration:
  1. What is the recommended procedure to test 2G, 3G, and 4G network connectivity on the HL7812 EVK?
  2. Are there specific AT commands to configure or switch between different network modes (2G/3G/4G)?
  3. Is there any reference documentation or application note available for network configuration and testing on HL7812?
  4. What is the recommended way to verify internet connectivity, such as ping tests or data session validation?
  5. Could you please share any sample AT command sequences or references for network registration and data testing?
Below are the module and firmware details for your reference:
ATI9 Output:
  • Firmware Version: HL7812.5.4.12.2-23.01.0.FreeRTOS.rc2
  • Release Date: 2023/03/30
  • Legato RTOS: 23.01.0.FreeRTOS.rc2
  • U-Boot Version: 01.03
  • MAC Stack: ALT1250_03_02_00_22_24731_2G
  • IMEI-SV: 3511444414114212
We would appreciate your support in guiding us with the correct testing methodology and documentation for HL7812.
The module does not support 3G network , so you cannot test 3G
What network do you have in shanghai? Cat-m or nbiot?
You can use at+ksrat to configure different technology, and you can use at+cereg command to check network registration status.
Btw, your firmware is quite old, please upgrade it
We are currently testing the HL7812 EVK with a China SIM card that supports 2G and 4G networks only (Cat-M and NB-IoT are not supported by the SIM). We would like your guidance on validating 2G and 4G data connectivity when the module is interfaced with a host processor.
Our team is testing from Shanghai, China, where live 2G and 4G networks are available.
We kindly request your support on the following points:
  1. What is the recommended test procedure for validating 2G and 4G data connectivity on the HL7812 EVK with a host processor?
  2. Are there specific AT commands to configure and switch between 2G and 4G network modes on HL7812?
  3. What is the recommended method to verify internet connectivity, such as:
  • PDP context establishment
  • Ping or data transfer tests
  • Socket-based data testing from the host
  1. Is there any reference documentation, application note, or sample AT command sequence available specifically for 2G/4G data testing on HL7812?
ATI9 Output:
  • Firmware Version: HL7812.5.5.14.0-23.12.0.FreeRTOS.w49
  • Firmware Package: HL78xx.5.5.14.0.RK_03_02_00_00_40522_001.20240207
  • Build Date: 2024/02/07
  • IMEI-SV: 3511444418718917
  • Legato RTOS: 23.12.0.FreeRTOS.w49
  • MAC Stack: ALT1250_03_02_00_00_40521_2G
We would appreciate your guidance on the correct configuration and testing methodology for 2G and 4G data services on this firmware.
Thank you for your time and support. We look forward to your response.
since catM and NBIOT is not supported by your sim, so you cannot test 4G
Please check if your SIM card can support 2G and put it in your mobile phone to set to 2G only and see if it can register network in your location.
For the testing for HL7812, you can use at+ksrat to configure to 2G, and you can use at+cereg command to check network registration status.
