Regarding WP76xx GNSS function
can I use GNSS function of non GNSS SKU through AT commad?
which sku are you using?
Hi
I used SKU# 1104558 .
yes, i think it just disable the NMEA port in AT!USBCOMP and disable the “GPSENABLE” flag in AT!CUSTOM in factory
You better enable these flags and see if GNSS function can be used in your module
Does your response mean i cannot use GNSS function in SKU# 1104558?
is there no any method to use GNSS in SKU# 1104558?
no, i mean you can do the following and see if GNSS can be enabled in your module:
AT!ENTERCND="A710"
AT!USBCOMP=1,1,8010D
AT!CUSTOM="GPSENABLE",1
AT!RESET
