RC7620-1 Rel 9 - AT&V - Corrupted response
Hi ,
I’m testing RC7620-1 Rel 9
With release 9 I’m facing with this issue:
I cannot receive a correct answer from AT&V command at baudrate 230400 or greater.
TX: AT&K3
GSM RX: OK
TX: AT+IFC=2,2
GSM RX: OK
TX: AT+ICF=3,3
GSM RX: OK
TX: AT+KSLEEP=2
GSM RX: OK
TX: AT&D0
GSM RX: OK
TX: AT&V
GSM RX: &C: 2; &D: 0; &E: 0; &F: 0; &K: 3; &S: 0; &W: 0; E: 0; L: 0; M: 0; N: 0;
Q: 0; V: 1; X: 1; Z: 0; \Q: 3; \S: 0; \V: 0; O: 0; S0: 0; S2: 43; S3: 13;
S4: 10; S5: 8; S6: 2; S7: 0; S8: 2; S9: 6; S10: 14; S11: 95; S30: 0;
S95: 1; S103: 1; S104: 1; ^DSCI: 0; ^HSMSSS: 0,0,1,0; !MECALL: 0,0;
!MECALLCFG: 0,0,0,“”,A%= <<— MESS MESS MESS!
jjP55<<— MESS MESS MESS!
As you can see I’m receiving some bytes and after some dirty characters.
I’m using hardware flow controls.
In Release 8, with the same baudrates, same commands, worked well.
Also if I set port to baud rate at 115200 the response is good.
no problem is found on my side, seems to be your hardware issue:
ati3
Model: RC7620
Revision: SWI9X07H_00.08.24.02 f90cbd jenkins 2022/03/21 03:47:54
IMEI: 353634110012345
IMEI SV: 19
FSN: 7Q947200012345
+GCAP: +CGSM
at&v
&C: 2; &D: 2; &E: 0; &F: 0; &K: 0; &S: 0; &W: 0; E: 1; L: 0; M: 0; N: 0;
!MECALLCFG: 0,0,0,"",0,0,5,8,1; !MECALLGPIO: 0,3,0; !MECALLMSD: "";
!MECALLMSDBLK: 1,""; !MECALLOPMODE: 0; !MECALLTXMODE: 0;
!MECALLUSLMSK: 0
Ok thank you jyijyi, which baudrate you used? Flow control enabled?
I forgot to mention I’m on UART1
I am using baud 230400 in UART1
