RC7611-1 Power From Li-Ion Directly?
Hi All -
Wondering if anyone has experience powering the RC7611-1 directly from a lithium-ion battery rather than a regulated supply. I have done this in the past with cellular modems from other manufacturers, but this configuration is not called out in the technical spec for the 76xx.
Thanks!
@dan
As long as you stay within the limits of the power supply stated in the WP76 PTS, which is not the full range that a Li ion battery can go (so you might need to watch the charging circuit to see what it will take the battery to), then it should be fine just make sure it can deliver the current required otherwise you will damage the battery.
