Q2687RD Voice Channel Problem
I can’t hear the audio through the mic and speaker through the SP1 or SP2. I cant hear from the remote side, the dtmf tone that I can send through the AT commands, which I find strange.
Originally, the equipment had a Q2687Classic installed, which was replaced by a Q2687RD.
The firmware installed in the module is 7.52 and the functionality of the program in the module, is run normally, gpios checks status, etc.
The problem is in the audio tx and rx of voice channel.
Can I check any medition point in the module??.
did you compare AT+SPEAKER? command with the OK module?
BTW, it is strange that even DTMF tone cannot be sent out, I am wondering if this is network related issue, are you able to send SMS or receive SMS in module?
Thanks for the answer. Yes, I have checked the speaker selection, according to the connection. I’ve worked with the modules since q24, I have some experience, that’s why I’m struck by what happens, especially that the tone doesn’t come out.
My idea was to try to rule out any internal problems in the module, since the general functionality would be ok.
I have tested the chip in a q24 module and it works ok. In case there was any kind of restriction on the part of the company. The module is enabled, the program runs normally. Why does it ask me if it sends SMS?, how do you associate it with the voice channel
it is strange that even DTMF tone cannot be sent out, I am wondering if this is network registration related issue
It’s very strange. I can answer the incoming call, I see the message that the voice channel is opened and I can’t hear anything.
So with same firmware and OAT application, q2687classic is working but not for q2687rd?
Do you have the q2687 dev kit?
You can isolate if this is hardware issue
No, not working in any type.
Then it could be hardware issue
I don’t have the dev kit, I have a board where the module was installed in service
How is the testing on that board then with same firmware and OAT application in2687classic and q2687rd?
The version of firmware are differernts for the type of modules.
I dont understand…
Didn’t you can change the firmware?
I’m looking on eBay to buy another module… I don’t have a local supplier
The installed firmware was the same as the one that had been installed in the module in serviceI doubt the hardware, but I find it strange that only that fails, so I wanted to see if there was any measurement to rule out that problem
how about OAT application?
Are they the same?
Have you ever tried to stop the OAT application by AT+WOPEN=0 to see if there is any improvement?
Have you tried more Q2687RD to see if all of them having the same problem?
My doubt is because I have tested the modules on the same board. and the same thing happens in both modules. The OAT has been compiled with different IDEs, one was the same as the q2687Classic module was in service and the other has been compiled in the software that I have recently installed due to the different hardware version, etc. That’s why I don’t know if the board could have caused some damage to both modules when inserting them or what could have happened… So I wanted to know if there was a way to test the module in some way.
quite confused…
anyway, you better do some more test first to isolate if this is hardware issue
