Am using Q2686G.
The firmware version is :: R74_00gg.Q2686G
Application OS :: 06.21
Boot loader version :: V08b0e
When trying to connect to GPRS, getting the Cid Info is giving problem.
what am doing is,
waiting for WIND: 7 event
Then doing GPRS setup [with Cid as ‘1’]and handler subscribe, both are returning OK
In handler, am receving
i. Event::25[ ADL_GPRS_EVENT_SETUP_OK] with Cid::1. Then am doing adl_gprsAct(1).This also returning OK
ii. then, receiving Event::27[ADL_GPRS_EVENT_ME_ATTACH] with Cid::1, in shell am getting
In our forum, one of our friend told to wait for event “WIND : 4”[product is ready to process AT commands.]
I did that. But i cant get anything different. Problem remain the same.
“WIND :7” will come, when the n/w service is available for emergency call. I tried that. that time, i got some more lines in shell,
" +WIND: 15,1,“Airtel”,2,“Airtel”,3,“+22”,4,“11/01/14,09:44:48+22”,6,“0” "
Is it wrong? Why the Cid value changed to 5. Its limit is[0-4] only.
Sir,
Thank you for your replay. I waited for a long time. But after WIND: 7 , also some events related to SMS and calls are only coming. I checked in user guide. Can not find any API to check or to do registration . Kindly help me .
Thank you awneil. Now, I installed GPRS hadler after the unit is ready to process the AT commands. Then, after the GPRS handler received, the “ADL_GPRS_EVENT_ME_ATTACH”, am calling the GPRS setup function. Now, the Cid is not changing and am getting the DNS1,local ip .
But, when i call “wip_TCPClientCreate” with one IP and port number[In which am already running server], the create is returning OK . But when i try to transmit some data using GPRS using “wip_write” it is giving error as, " WIP_CEV_ERROR" and error number is “-989”. Saying Destination Host is Un-reachable. But that host is up and waiting in that socket.
Is there any way to confirm the GPRS functionality ?
thank you awneil. With out using GPRS event handler, now i tried.
I called “wip_netInit” at the beginning. Then waiting for event 15 to occur. [till the CPU receive NITZ info from network]. I get,
" +WIND: 15,1,“Airtel”,2,“Airtel”,3,“+22”,4,“11/01/18,07:01:14+22”,6,“0” "
after that i called gprs bearer function which will do, wip_bearerOpen, wip_bearerSetOpts, and wip_bearerStart . but wip_bearerStart get failed with following error,
Not all networks give NITZ at all, and some that do only give it after GPRS attach.
So it’s no better than waiting for GPRS-Attach - but possibly worse!
thank you awneil… now i am trying with new sim card. As you warned me,this is not returning NITZ. Thank you.
so, i am sending “AT+CREG=1” command using adl_atCmdCreate API. After this API’s success, i am calling gprs setup function.
Now am getting WIP_BERR_OK_INPROGRESS and after some time WIP_BEV_CONN_FAILED. Am getting WIP_BOPT_ERROR value as 4. " WIP_BOPT_ERROR::4 " .
But its not negative, and this error code is not listed in document.
