I have the following setup:
Q24Plus (Q24PL003), OpenAT 3.13
I’m using the WIP plugin, but in this example I don’t open a socket.
I’m trying to work with GPO1 and I’m not able to toggle the pin like I thought I should be able to.
Following is my code:
s8 init_gpo1(void)
return adl_ioSubscribe (ADL_IO_Q24PLUS_GPO_1, 0, 0x00000000, 0, NULL);
void ioWriter(void)
static testFlag=FALSE;
s8 result;
if(testFlag)
result = adl_ioWrite( (u8) gpio_handle, ADL_IO_Q24PLUS_GPO_1, 0);
if(result!=OK)
TRACE((1, "cannot reset GPO1 "));
else
TRACE((1, "IO tester reset "));
testFlag = FALSE;
else
result = adl_ioWrite( (u8) gpio_handle, ADL_IO_Q24PLUS_GPO_1, ADL_IO_Q24PLUS_GPO_1);
if(result!=OK)
TRACE((1, "cannot set GPO1 "));
else
TRACE((1, "IO Tester Set "));
testFlag = TRUE;
void timerHandler(u8 id)
ioWriter(); //toggle every 500 ms
static s8 gpio_handle = -1;
adl_tmr_t *tt;
u16 timeout_period = 5;
void appli_entry_point()
gpio_handle=init_gpo1();
wip_debug( "[GPIO]: gpio_handle %i...\n", gpio_handle);
tt=adl_tmrSubscribe(TRUE,timeout_period,ADL_TMR_TYPE_100MS,(adl_tmrHandler_t)timerHandler);
All this code does is toggle GPO_1 every 500 ms. I have an oscilliscope attached to my GPO_1 pin and I don’t see the voltage level change. It’s always “low”.
The value of gpio_handle is 5. In ioWriter, the adl_ioWrite calls always return “OK”.
Any ideas what’s wrong?
Thanks in advance,
Coleman
