Hi all!!, im trying to read a cell wich i`ve already write using the adl_adInfo funtion. First i suscribe the cell with success, then i use the info function but a ADL_RET_ERR_PARAM error appears!. I really dont know what im doing wrong.
This is the code
bool adStorage_ReadMem(u8 *BufferRdMem,int CELLID)
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:Inside adStorage_ReadMem"));
adStorage_SuscribeCELLHandler=adl_adSubscribe(CELLID,ADL_AD_SIZE_UNDEF);
switch(adStorage_SuscribeCELLHandler)
case OK:
TRACE((1,"[wav_adStorage.c][adStorage_SuscribeCELLHandler]:sadl_adSubscribe OK"));
s32 respuesta=adl_adInfo(adStorage_SuscribeCELLHandler,adStorage_Info);
switch(respuesta)
case OK: //on success
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:adl_adInfo OK"));
u8 datoaux;
datoaux= (u8*)(adStorage_Info->data); TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:Valor de datosaux %d",datoaux));
return TRUE;
break;
case ADL_RET_ERR_PARAM:
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:ADL_RET_ERR_PARAM"));
return FALSE;
break;
case ADL_RET_ERR_UNKNOWN_HDL: //if the handle was not subscribed
tRACE((1,"[wav_adStorage.c]Storage_ReadMem]:ADL_RET_ERR_UNKNOWN_HDL"));
return FALSE;
break;
case ADL_RET_ERR_BAD_STATE: //if the required cell is a not finalized or an undefined size
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:ADL_RET_ERR_BAD_STATE"));
return FALSE;
break;
case ADL_RET_ERR_SERVICE_LOCKED: //if the function was called from a low level interrupt handler (the function is forbidden in this context)
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:ADL_RET_ERR_SERVICE_LOCKED"));
return FALSE;
break;
break;
case ADL_RET_ERR_ALREADY_SUBSCRIBED: //if the cell is already subscribed
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:ADL_RET_ERR_ALREADY_SUBSCRIBED"));
break;
case ADL_AD_RET_ERR_OVERFLOW: //if there is not enough allocated space
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:ADL_AD_RET_ERR_OVERFLOW"));
break;
case ADL_AD_RET_ERR_NOT_AVAILABLE: // if there is no A&D space available on the product
TRACE((1,"[wav_adStorage.c][adStorage_ReadMem]:ADL_AD_RET_ERR_NOT_AVAILABLE "));
break;
case ADL_RET_ERR_PARAM: // if the CellId parameter is 0xFFFFFFFF (this value should not be used as an A&D Cell ID)
break;
case ADL_RET_ERR_BAD_STATE: // (when subscribing an undefined size cell) if another undefined size cell is already subscribed and not finalized
break;
break;
return FALSE;
