Hi Jiten9,
This kind of error usually comes when ARM compiler is not installed on the system and you try to compile your OAT applicaton using ARM compiler. I experience similar problem when I tried to compile my OAT application with ARM compiler without having the ARM compiler itself.
You can try reinstalling ARM compiler again and then install Open-AT again.
I think this should help solving the problem.
Regards,
OpenAT Fan.
