problem testing the HelloWorld
Did anyone know how to solve this problem
I use VC++6.0 and load the Open AT SDK V3.14 I got from the training course into my computer
When I build a project sample ( say HelloWorld ) it did not generate DWL files.
Similarly encounter when I create new project, with only a comment line
instead I get error message as below
make ***[make_single_bin] Error 1
[wm make error #1 ] Build Error
I try using Eclipse. Similary result
I suspect linking error.
Is there some setting I missed during installation or setup?
Why do you suspect that?
Linking happens after compiling - so do you see all the messages that confirm that compiling worked?
One thing to note: the build tools won’t work if there are any spaces anywhere is any pathnames used by the tools and/or the source files…
Yes, compling is OK. it then goes to linking and then I get this error.
I have try reinstall SDK, and also in other computer.
I try using C++ 6.00 and also Eclipse. All same result.
see portion of capture log
… Compiling hello_world.c
Copy all needed library and object files
Make links C:/OpenAT/OS/3.13.02/ADL/gcc_wmadl_3.13.1.1.0.lib …/out/gcc_wmadl_3.13.1.1.0.lib
… Link step in progress …
… Link gcc_Hello_World.bin …
make: *** [make_single_bin] Error 1
Done.
[wmmake error #1] Build error.
We get a new SDK installation disk from our local distributor and reload and everything is fine now.
Look like my SDK was broken.
