I am new to this forum so i hope i am doing well. I have an Airlink MP70. Via the provider we have received a static IP address. When I try to ping the router it gives no response. The router is online though. Do I need to change anything in the settings?
Welcome you to our community.
What firmware ALEOS, radio module version are you using? Have you observed the static IP address in your MP70? Go to ACEmanager-> Status->Cellular->Cellular IP Address to check it.
If you still observe this issue after updating to the latest FW, please share your MP70 device template and log file with me.
The configuration file is in ACEmanager → Template, provide any name you desire for the Template Name, and then press Download to retrieve the template file.
The log file is in ACEmanager → Admin → Log → Configure Logging, and make sure that the Linux Syslog is set to “Display”. Be sure to “apply” the new settings. Then go to Admin → Log → View Log in order to access the log. Press “Download log” (or save) to store the log information into a text file.
