Is it possible the disable the external antenna on this module? It can detect a short, so I’m wondering if it’s possible to then respond by disabling the external one via command and keep some level of function?
I have checked and it is not possible to disable the external antenna via a command. Only solution to keep function is to remove the external antenna which will cause the module to switch back to the patch antenna.
Regards,
Phillip
Thanks for the info - much appreciated!
Phil.
