I’ve defined adl_InitTasks [] table to contain entries about multiple tasks (ie. two, priority 1 and 2 respectively). Now in each task body i’m only calling: adl_atSendResponse ( ADL_AT_UNS, “\r\nTASKn STARTED\r\n” ); .
I’m wondering why this happen: In RTE build all messages are received by UART1 connected terminal. In Target built no data is received.
Then, I’ve commented out adl_InitTasks [] , and one task’s body copied into newly defined adl_main() function body. In both builds text was displayed.
Using Open AT Software Suite v2.02.
Hi, i have the same problem with fastrack supreme . I’m running UART access sample program, task definition table looks like :
const adl_InitTasks_t adl_InitTasks [] =
{ mtInit, 4096, “MainTask”, 2 },
{ stInit, 4096, “SecondTask”, 1 },
{ NULL, 0, NULL, 0 }
When runing on Wireless CPU module, i’ see only message from main task body. Second task does not starting anyway.
Did you solve this issue?
regards
it is all about UART_access sample (from \OpenAT\OS\6.20.04\ADL\samples\UART_access
stInit (second task) does not start at all.
AT+WDU=1,“UART1”,115200 command causes unit restart.
