Help me set up the Module for Ucell.
It does not accept the command at!usbcomp=1,3,100d
how about using AT!USBCOMP=1,1,100d
passed, thanks.
You can use the optimal configuration commands. that everything worked well
ati3
at!impref?
at!entercnd=“A710”
at!image?
at!selrat?
aT!gstatus?
AT+cpin?
AT!uims?
AT+cfun?
AT!band?
AT+CGDCONT?
at!entercnd=“A710”
At!usbcomp?
At!usbcomp=?
at!entercnd=“A710”
At!usbcomp=1,1,100d
At!reset
What do you say about these commands?
add this command?:
at+cgdcont=1,“IP”,"internet.ucell.uz "
what do you mean actually?
How do I set it up correctly? Or leave it as it is
did you check if the module can attach network in AT!GSTATUS?
I can see module has attached to network, then what is the problem now?
Everything is fine. Thanks
