I’m bit struggle getting this MC8705 run on my openwrt barrier break. I have build and run on my router and i can confirm MC8705 is connected properly. However the OS seems failed to detect the card for some reason.
Do i need to install extra driver so that i can use MC8705 card?
root@Gargoyle:/# dmesg | grep tty
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz root=/dev/sda2
rootfstype=ext4 rootwait console=ttyS0,38400n8 noinitrd
[ 0.000000] console [ttyS0] enabled
[ 0.438270] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a NS16550A
[ 0.457148] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a NS16550A
[ 8.160325] usb 1-2: Sierra USB modem converter now attached to ttyUSB0
[ 8.213879] usb 1-2: Sierra USB modem converter now attached to ttyUSB1
[ 8.274693] usb 1-2: Sierra USB modem converter now attached to ttyUSB2
[ 8.337052] usb 1-2: Sierra USB modem converter now attached to ttyUSB3
[ 8.391793] usb 1-2: Sierra USB modem converter now attached to ttyUSB4
[ 8.447675] usb 1-2: Sierra USB modem converter now attached to ttyUSB5
[ 8.507425] usb 1-2: Sierra USB modem converter now attached to ttyUSB6
root@Gargoyle:/# opkg list-installed | grep usb
kmod-ledtrig-usbdev - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-core - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-net - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-net-cdc-ether - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-net-cdc-mbim - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-net-cdc-ncm - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-net-sierrawireless - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-ohci - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-serial - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-serial-ipw - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-serial-option - 3.10.49-1-7c745cc448ed36a3954c9f92c8478955
kmod-usb-serial-sierrawireless - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-serial-wwan - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-uhci - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb-wdm - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb2 - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usb2-pci - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
kmod-usbip - 3.10.49-1-a9ce25fdf3b460ac31f527119dbcba8d
libusb-1.0 - 1.0.9-1
usb-modeswitch - 2014-07-18-01ecc3b9764d1dd89cf36ede0a2d98f9adb0cd33
usbutils - 007-1
root@Gargoyle:/# modinfo sierra
module: /lib/modules/3.10.49/sierra.ko
license: GPL
depends: usbserial,usbcore
root@Gargoyle:/# modinfo sierra_net
module: /lib/modules/3.10.49/sierra_net.ko
license: GPL
depends: usbnet,usbcore
root@Gargoyle:/# ls /dev
bus net root ttyUSB1
console network_latency rtc0 ttyUSB2
cpu network_throughput sda ttyUSB3
cpu_dma_latency null sda1 ttyUSB4
crypto nvram sda2 ttyUSB5
full port shm ttyUSB6
hwrng ppp tty urandom
kmsg ptmx ttyS0 watchdog
log pts ttyS1 zero
mem random ttyUSB0
any help please? i am desperate to get some guidance as I have tried various combination.
many thanks.
